AFPR is it really worth it and what will it do
Old Apr 15, 2002 | 09:20 PM
primer84z's Avatar
what the hell is a adjustable fuel pressure regulator for? ive heard people talk about them but i have no clue what they do or how much i would gain from getting one. can someone help me out here?
Old Apr 15, 2002 | 10:07 PM
primer84z's Avatar
anyone?
Old Apr 15, 2002 | 10:10 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Q: What fuel pressure setting will give me the best performance?
A: The stock setting is 42 PSI. Much track testing has showed that any type of increase will greatly benefit both horse power and torque. Here's some dyno testing on a stock 350 motor which substantiates those claims:
42 PSI (stock) 46 PSI 50 PSI
RPM Torq HP Torq/diff HP/diff Torq/diff HP/diff
2250 237.7 101.8 254.9/17.2 109.2/ 7.4 275.0/37.3 117.8/16.0
2500 241.7 115.1 262.1/20.4 124.8/ 9.7 283.3/41.6 134.9/19.8
2750 241.5 126.5 275.2/33.7 144.1/17.6 297.0/55.5 155.5/29.0
3000 237.1 135.4 278.2/41.1 158.9/23.5 305.5/68.4 174.5/39.1
3250 233.8 144.7 278.9/45.1 172.6/27.9 311.3/77.5 192.6/47.9
3500 241.0 160.6 278.2/37.2 185.4/24.8 309.5/68.5 206.3/45.7
3750 246.6 176.1 283.4/36.8 202.4/26.8 303.3/56.7 216.6/40.5
4000 250.4 190.7 278.3/27.9 212.0/21.3 298.0/47.6 227.0/36.3
4250 251.6 203.6 272.5/20.9 220.5/16.9 289.1/37.5 233.9/30.3
4500 253.5 217.2 257.3/ 4.2 220.5/ 3.3 277.0/23.5 237.3/20.1
4750 245.0 221.6 242.1/-2.9 219.0/-2.6 266.4/21.4 240.9/19.3
5000 227.6 216.7 225.0/-1.4 214.2/-2.5 237.8/10.2 226.4/ 9.7
It shows that by increasing the fuel pressure to 50 PSI, results in maximum torque increase of 58 ft-lbs (along with a much flatter torque curve) and a maximum horse power increase of 19 HP over stock. 46 PSI also provides a noticable increase which should work well for day-to-day street driving. An adjustable fuel pressure regulator (see Chap 5.2) is required to increase the fuel pressure.
-Tech Articles @Thirdgen.org
If thats too hard to read, go here https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Old Apr 15, 2002 | 10:17 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
He's running a carburetor which means he is only running about 6psi. I'd say an AFPR would not benefit you at all.
good luck,
Craig
Old Apr 15, 2002 | 10:51 PM
Car: 1988 IROC-Z
Engine: 427 SBC
good luck,
Craig
Whoops
Old Apr 16, 2002 | 04:36 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
But for anyone who does have TPI and is reading this... that table provides false info. In theory it could produce a +56 tq but it really wont. I raised mine to 50psi and got slower in the 1/4. I mean think about it... the L98 is 345ft/lbs stock... u mean to tell me that nothing but a $75 AFPR is gonna yield 345+56= 401ft/lbs out of a bone stock motor? I am thinking no. Anyone else have thoughts/ideas/input on this?
In addition, 50psi can produce knock in the upper RPM's and make the ECM retard the timing.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Reid Fleming
Oct 10, 2015 09:56 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
