why is my car running so hot...what can fix it?
Old Apr 15, 2002 | 10:53 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i went to the strip the other night and my car was running 220-240 the whole night and my carb was bogging becuz of it.....i flushed my system the next day got a new radiator cap and made it so i can turn on my fan manually....but its still not running much cooler......one guy told me that with his headers his car would run a lot cooler....is this true.....if so then i will just wait until i do that and not spend money on a new water pump or something along those lines.....
Old Apr 15, 2002 | 11:08 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Running headers is not a way to go about keeping a car cool.
What thermostat are you using? Condition of your lower radiator hose. Air dam?
Old Apr 15, 2002 | 11:10 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
i gotta 180 stat.....i replaced the radiator hoses when i changed the water pump last fall......and my car runs cool when im cruzin along the highway so i know its not the air dam
Old Apr 15, 2002 | 11:13 PM
Car: 99 Formula
Axle/Gears: 342
Make sure your timing is correct and you're not running lean.
Old Apr 15, 2002 | 11:16 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
i have no idea how to adjust richness/leanness.......and i think my car is running advanced some cuz it seems to run faster........
Old Apr 16, 2002 | 12:13 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
as i recall the 84 still ran a clutch fan, i'd check the operation of the clutch for the fan. also pull the radiator and check for blockage of air in front ot the radiator especially between the a/c condensor and the radiator if you have it.
Old Apr 16, 2002 | 11:02 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
no i have an eletric fan...stock.....i just hooked up a switch to it so i can turn it on at any time
but i still dont think its gonna help much
as for something blocking the radiator....i dont think anything is.....it all loooks good....but who knows....maybe the inside is all clogged up or something....i know when i was flushing the system i saw a lot of white crap on the inside....and i dont think very much of it came out......
Old Apr 17, 2002 | 05:32 PM
zippy's Avatar
Engine: 5.3L
quite often the problem isn't inside the radiator, but the outside where the air is supposed to flow through.
Old Apr 17, 2002 | 07:42 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
run water wetter and straight distilled water in the summer, this should drop you 20-25 degrees..........you could also look into getting and aluminum radiator and a seperate tranny cooler so the rad isnt working overtime.............dont know how old the rad is but it may be flowing poorly........another trick is take out the thermostat............on the flat ring around the stat drill 4 .. 1/8" holes............this will let water trickle through slowly and mix with the hot water in the heads .........dont know bout you but if its over 85 degrees my car stays put......
Old Apr 17, 2002 | 07:43 PM
wasp's Avatar
get a 160 stat too
Old Apr 17, 2002 | 07:45 PM
Car: 99 Formula
Axle/Gears: 342
I hear straight water can lead to rust.
Old Apr 17, 2002 | 07:53 PM
82camaro's Avatar
Car: 82 camaro SC
If it runs cool down the highway and not cool around town at slower speeds, the fan isn't pulling enough air. What kind of fan are you running? Shroud?
Old Apr 17, 2002 | 08:02 PM
Car: 99 Formula
Axle/Gears: 342
Forgot about that, I don't have a shroud, but I need to get one for summer, or I may switch to an electrical one.
Old Apr 17, 2002 | 10:05 PM
87transam5.7tpi's Avatar
ya it can so just buy 2-3 bottles of "water wetter" and you'll be set.
Old Apr 17, 2002 | 11:15 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
the fan is stock...i talked to some guy and he said it should b pulling enough air and i dont know what kinda shroud it has.....and i had a 160 stat in there when i got it but it still overheated so i put a 180 in it and it runs the same......
Old Apr 18, 2002 | 06:14 AM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I noticed a 20 degree reduction after switching to synthetic oil.
Old Apr 18, 2002 | 08:26 AM
dps8315's Avatar
No Shrowd
Haven't been able to find one at a junk yard, either... Every single one of them is cracked big time... found one off a different year V6 and it wasn't big enough.
Any ideas where I can get one? Without it, my radiator has this jimmy-rig support and I know the fan is pushing the air in that it needs to.
Also, any of you open element guys think your car runs hotter because of it? Like, since the air going through your carb is probably 30 degrees hotter to begin with, do you think your engine runs hotter?
James
Old Apr 18, 2002 | 10:57 AM
TBI305Camaro's Avatar
the open element should effect it mine doesnt
Old Apr 18, 2002 | 11:27 AM
gruveb's Avatar
Car: 1989 IROC-1
This is my nemesis-heat!
I also have an '84 Z-28 also.
I've had the same trouble, here's what I have done with success. I'm not guessing, this is what worked. I can also tell you what hasn't worked well.
I did like you have, hooked up a manual switch. Good idea.
Use distilled water (summer only) a rust/lubricant additive and water wetter, a couple of bottles. It works--big time.
A stewart water pump. Stage 1 is plenty. http://www.stewartcomponents.com/
I am running a 160* thermostat right now, but am actually going to go up to a 180* high flow stat. Here's why.
160 opens very early, and stays open. The coolant doesn't get a chance to stay in the radiator to cool down b/c the stat is always open.
A 180* stat should close more often, allowing the coolant to set in the radiator cooling down!
A very trusted mechanic here was running a 400 sbc and was having trouble with this very same problem, until he switched to a higher temp thermostat....and it worked. He's been doing it ever since. So I am going to follow suit.
What water wetter does is dissipate heat more quickly while raising the boiling point of water.
What anti-freeze does is acts as a stablizer. It raises the boiling point and lowers the freezing point. However it also limits the ability to remove heat. Water wetter doesn't affect the freezing point, but does raise the boiling point and also dissipates heat more effectively than even just pure water.
Old Apr 18, 2002 | 04:58 PM
wasp's Avatar
one bottle treats a typical cooling system..........what it does is it makes it so the air bubbles in your system are smaller........the air inside a bubble isnt dissapating heat......the smaller the bubble the better the cooling
Old Apr 18, 2002 | 05:28 PM
willdog666's Avatar
Car: 1988 camaro sc
Engine: 350 tbi swap
Axle/Gears: posi 3:23 swap
i usea Flow Kooler high flow water pump on my 350 with an alumium radiator single stock electric fan(wired so i can turn it on and off)and a 180 stat, and it actually almost runs too cold on the highway and never gets above 180 even in 100 degree bumper to bumper traffic. i think the water pump helped the most and is well worth the $. wish'd i gone with an aluminum one though but i'm too cheap.
Attached Thumbnails why is my car running so hot...what can fix it?-liflowgo.gif
Old Apr 18, 2002 | 05:46 PM
simon's Avatar
Look just below the radiator support member. You should have a 5" piece of plastic that runs the length of the radiator. This is called an "air dam". If you don't have one then go get one - you need it. I bought mine fromt the dealer for around $30.
Old Apr 18, 2002 | 05:47 PM
willdog666's Avatar
Car: 1988 camaro sc
oh yeah the water pump was about 80 bucks i think
Old Apr 18, 2002 | 06:19 PM
wasp's Avatar
thirdgen resource has em cheap too, new ones too
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
Amillionoh7
Aug 7, 2015 01:24 PM
