WOT/Fuel Injectors/Fuel pressure Question
Old Apr 16, 2002 | 12:07 PM
ORAY777's Avatar
Is it true that at WOT the computer does not have control of the injectors and that fuel pressure is in more control?
Old Apr 16, 2002 | 12:24 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
No, the ECM always controls the Injector Pulse Width. What happens is the ECM does not make "fuel corrections" based on the O2 sensor when in WOT - it relies solely on the tabels within the ECM and the other sensor readings.
Old Apr 17, 2002 | 08:19 AM
ORAY777's Avatar
So It is important to get a aftermarket chip or burn one to get the full potential of your engine even when you raise the fuel pressure right?
Old Apr 17, 2002 | 10:14 AM
Car: Death Mobile
Engine: 666 c.i.
Aftermarket chips are generally too rich as is. It is best to tune the eprom to the specific pressure you wish to run. This requires "hands on" tuning and monitoring - not an eprom "off-the-shelf, by mail or burnt-by-specification". Raising fuel pressure does not behave in a direct "linear relationship". It has it's greatest effect in WOT and least effect at low load/part-throttle. So you generally adjust only part of the fuel tables.
MustangBeater20
Oct 29, 2022 09:20 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
bamaboy0323
Aug 15, 2015 07:20 AM
