What Mods for $1k?
Old Apr 17, 2002 | 12:07 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
What Mods for $1k?
I have some money from tax refund, Just wondering what I should do? Suspension, brakes, trans, engine, interier etc.
What do you think?
I have already done full exhaust, and have a shift kit ready to be installed. Also a new rear is a priority, just have to find one .
Chris
Old Apr 17, 2002 | 12:42 AM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
SFCs or cam. Both will make an incredible difference in your ride. Or maybe even a new stall converter. I hear up to 4 tenths in the 1/4 with about a 2200 stall on stock motor. Of course unless you have a manual gearbox.
Old Apr 17, 2002 | 03:23 AM
Jza's Avatar
Jza
This is assuming you have a 305TBI, I'd get gears or suspension modifications. The TC was a good idea too, but I'd hold off on that for now. I'd probably not get a cam this time, either, unless you're never gonna swap the motor out for something better. The idea I'm presenting is doing modifications that benefit you now, but will also carry over and benefit a bigger motor. Getting a cam or TC now that works good with the 305, could carry over, but might not be the best for a 350, and you'd have to buy the part twice (once for the 305, and once for the 350). Likewise, getting a good cam or TC for a 350 and running it on your 305 until then would suck in the meantime (even though you'd only have to buy it once).
If you're going to keep the 305, then a cam, or saving a little more and getting some sweet heads will make some noticable improvements as well as setting the stage for future modifications.
But I like a car that can handle and make short bursts of speed better than a car that can go *****-to-the-wall, but only in a straight line. That's why I concentrated on suspension mods first, with only occasional meaningless engine mods.
Old Apr 17, 2002 | 02:39 PM
Car: 92' RS
Engine: LO3
For suspension mods I was concidering the following:
SFC,LCA reloc brackets, LCA's, Panhard bar, maybe a Strut tower brace(I had the edel. 3-point one but had to sell it because it was for TPI and wouldn't clear my air cleaner.
I probably won't do a TQ arm bar in the case that I eventually do a T-56 swap.
I do have a 305TBI w/ 700R4, 2.72 one legger.
Old Apr 17, 2002 | 04:08 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd say go with gears, especially if you plan on getting a T-56. Maybe a cam swap too, unless you plan on getting rid of the 305.
Old Apr 17, 2002 | 04:13 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
SFC, heads and a cam.
Old Apr 17, 2002 | 05:01 PM
SoCo80p's Avatar
NOS kit
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
