how do I make my gas gauge work?
Old Apr 17, 2002 | 03:43 PM
Joshua Leslie's Avatar
hey all
thanx in advance for the replys.
the car is an 89 firebird, original TBI, now carbeurated.
I had to rewire the pump, so basically I ran a hot lead to a toggle switch, to the pump. and the nevative off the pump to the negative on the battery.
but the gauge didnt work.
now,the pump has died, so I am using a Holley external pump.
So how the heck do I get the gauge to work, I have tried hooking everything back up,but it still doesent work.
Joshua
Old Apr 17, 2002 | 04:17 PM
ronterry's Avatar
Car: '94 Corvette
The gauge should have (3) connectors. One positive, one negitive, one sender.
After you've checked that the pos. & neg, are present you'll need to verify that the sender wire from the tank float to the gauge is not compermized.
Does the gauge peg beyond full ? If it does then you have an open, since the gauge only reads between 0 (Empty) - 90 (Full) ohms. If you have an open circiut the ohms would be greater then 90 there by pegging the gauge.
If its stuck on empty, then check the pos & neg wires, disconnect the sender wire, does it do like mentioned above ? If nothing can get it to move, you may have sent 12 volts down the sender wire by accident, which = gauge death.
Ron
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
