two distributor questions--PLEASE HELP!
Old Apr 18, 2002 | 12:38 AM
cort351w's Avatar
This is on my 91:
1) What goes into the black connector on the distributor? Where would this thing probably be if it's not hooked up the distributor? (i.e. would it be hanging somewhere?)
2) When I pulled my distributor, I marked a lot of stuff, but not the rotor position . I've had the distributor sitting by itself while it was out and haven't moved the rotor.
Do I have decent enough chances that the rotor hasn't moved or should I search for how to put it back in with the motor at #1 TDC?
Old Apr 18, 2002 | 10:01 AM
Vader's Avatar
Cort,
If you are asking about the four-wire connector from the distributor, it connects to the ECM and EST harness. There is a three-wire black connector that should connect the HEI module to the ignition coil on older HEI designs, but I don't think your '91 will have that.
Old Apr 18, 2002 | 12:43 PM
Guest
Guest
Posts: n/a
The 91 should have 2 locations for wires, both go into the spark module. One is a 4 wire deal, the other is 2. Both shouldnt be far, probably hanging down just below the harness level on top of the tranny.
If you didnt mark it, I'd be putting it at TDC #1 and installing it that way. I can almost guarantee 100% you wont get it back in right otherwise.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
