My GTA just stalled, WTF????
Old Apr 19, 2002 | 08:46 PM
92GTA's Avatar
I had just taken her out of the garage and gone to the gas station when I came back and I had to do a 3 point turn in my parking lot. I had just made a hard Right so my wheels were all the way over and as soon as I put the car in reverse to backup it stalled, it just died!!!!! My car has NEVER stalled. It was at full running temp and my SLP chip keeps the idle at about 550 RPM when hot and @200 degrees. It started right up and had no other problems.
Was this just a fluke or a sign of a bigger problem ahead????? I'm not too worried but I want to make sure that nothing is wrong and that it was just a one time thing. I'm thinking that because it was at idle with the wheels were all the way over, that by putting it from drive to reverse it lowered to RPM's ever lower and the car just died but that doesn't make sense because it was runing in drive and the switch from drive to reverse is so fast that the engine wouldn't even notice in terms of the RPM's rising and droping right?
Alex
Old Apr 19, 2002 | 08:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm pretty sure in every car I've driven that when the wheels were all the way turned that I guess it put some kind of strain on the power steering that it lowered the idle a bit, maybe it lowered yours just enough to make the car stall. I would go and try turning the wheel the way you did and see if it happens again.
Old Apr 19, 2002 | 08:54 PM
92GTA's Avatar
So it just put a strain on the power steering having the wheels all the way over that it lowered the RPM's and it died? I don't think I want to go and try and make it happen again though.....
Old Apr 19, 2002 | 09:41 PM
Car: 99 Formula
Axle/Gears: 342
That would be my guess, but I'm no expert.
Old Apr 19, 2002 | 10:08 PM
TransAm87's Avatar
my problem in my power steering
I noticed in my car i as getting a hissing noise and not Excellent performance from my power steering, since my ac was shot, Cut that belt and cut the Smog pump belt and you'll tell a great difference is Power steering
Aj
Old Apr 20, 2002 | 12:23 AM
92GTA's Avatar
Well I tried recreating it while I was out and driving around tonight and I couldn't. My RPM's would get down to as low as 400 but it wouldn't stall. Wierd......
Old Apr 20, 2002 | 04:03 AM
Blackened's Avatar
Yeah really... who cares...
83 Crossfire TA
Jan 3, 2016 01:26 PM
amcnellis
Sep 16, 2015 04:16 PM
DARKmj16
Sep 9, 2015 04:07 PM
rjcme
Sep 5, 2015 01:23 PM
