How Much Valve Lift?
Old Apr 20, 2002 | 10:36 AM
ORAY777's Avatar
HOw much valve lift is safely possible without hitting the piston on a stock L98 Engine?
Old Apr 21, 2002 | 07:12 PM
Z28SpeedKing's Avatar
WELL , THE MAIN PROBLEM THAT YOU MAY HAVE IS COIL BIND. BEFOR I GOT MY NEW HEADS JUST TO SEE WHAT WOULD HAPPEN I BOLTED UP A SET OF 305 HEADS. THE CAM COMPLETLY COMPRESSED THE SPRING.
dONT KNOWIF THIS HELPED YOU BUT THATS WHAT HAPPENED TO ME
Old Apr 22, 2002 | 12:16 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
don't know exact number but it's at least .600, and as speedking said, you'll get coil bind with that much lift on stock springs. if you want to run a high lift cam, you'll need new springs that won't float or bind as well as screwed in studs so they don't pop out.
Jorlain
Oct 8, 2015 01:57 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
