How to achieve quick starts....
Old Apr 20, 2002 | 02:01 PM
v8powr's Avatar
Car runs good, not the fastest in the world, but runs pretty good. When its cold it takes about 4-5 secs to start. When its warm it starts as soon as i hit the key (which is obvious) How can i get it to start quicker cold? Ignition? Also how often should you adjust valve lash and how much does it cost if a shop does it at a labor rate of $50 per hour.
Old Apr 20, 2002 | 03:16 PM
BAK12484's Avatar
not too sure if there is a cure for any car really... unless you have top notch (read EXPENSIVE) ignition equipment, almost any car, new or old will start slower when it's cold.
I dont know how often you should lash the valves, but i suggest doing it yourself and saving some money. Chances are a shop will charge you for two hours of labor, even tho if you did it yourself you could finish in less time. Only bitch about is turning the crank, the rest is simple.
Old Apr 20, 2002 | 03:25 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
My car does the exact same thing, it just seems like it takes way longer than it should to turn over. I've learned to give it just a wee bit of gas and it kicks off faster... still, seems like it takes alot longer than it should...
Old Apr 20, 2002 | 06:36 PM
88ROC1LE's Avatar
I dunno guys, on my car I can start it when it's cold no prob, when it warms up it takes a little longer. Sometimes it will start on the first bump with no smoke other times it takes a while and smoke for a bit then no smoke. What's up with that???
Old Apr 20, 2002 | 06:51 PM
EvilCartman's Avatar
Car: '82 Z28
Mine starts up quicker at any temp than my buddy's 97 chevy truck When it's warm, all you have to do is bump the key and it fires off, morning isn't all that much different. Non cc-dist. 8.5 mm wires and a Mallory coil.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
