what's everybodys oil pressure hot, at idle?
Old Apr 20, 2002 | 04:12 PM
mckenzie's Avatar
my oil pressure cold is 60psi. when it warms up, and at idle, its appx 20psi. just wondering if anybody else is near the same. also, temp got up to appx 235? (just before mark between 220 and 260) with a/c on and sitting in traffic. dropped to 220 while driving. just polling to see what you guy are running. thanks, tom
Old Apr 20, 2002 | 04:44 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It's around 50psi cold @idle, when hot the rule of thumb is 10psi for every 1k rpms, mine is right with that, just a little more.
Old Apr 20, 2002 | 05:05 PM
mckenzie's Avatar
is that the pressure on the original 305 in your 86 iroc?thanks, tom
Old Apr 20, 2002 | 07:29 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
on my 88' iroc
Idle - Crusin - Temp
60PSI - 65PSI - 100*
40PSI - 50PSI - 230*
Old Apr 20, 2002 | 07:41 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
On my 88 350
At Idle:
Cold - 60 PSI
Warmed up - 30 PSI
:lala:
Old Apr 20, 2002 | 08:02 PM
Car: 99 Formula
Axle/Gears: 342
No, but the 305 was about the same, except when cold, if I remember correctly.
Old Apr 20, 2002 | 08:22 PM
sIcK pUpPy's Avatar
60 when it's cold, 15 at idle (operating temp) and 30 under load (warm).
Lates,
JD
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
