Auto Shifting
Auto Shifting
Guys I just want to make sure of something. When shifting in a auto w/ overdrive. Overdrive has the box, and plain old drive has just the D. And D is gear 1, 2, 3 and Overdriver is 4th right. Overdrive also is suppose to save gas, so if I always drive in overdrive I wont have and tranny problems right.
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
when you are in drive all it dose is lock out overdrive, thats is if your driving on a road that has a speed limit (what's that???) of say 35 your sposted to keep it in D so the tranny isent shifting back and fourth and your converter isent locking and unlocking. bacically if your not having a problem with it going back and fourth between gears just leav it in OD, I alawas did and never had a problem (til I swiched to a manual, now my racing clutch keeps blowing my slave cylenders out, damn pain in the *** cheap GM slave cylenders that cost $150)
3 spd / 4 spd overdrive
My girlfriend has a Celica GT with push button, on the fly Overdrive selection. Is the purpose of something like that performance oriented?
If you've got a 3 spd auto vs a 4 spd auto, same car otherwise, which one will win? It's like, the 4 spd will probably pull a little longer (overall time), and it won't top out on its gears, but on the other hand, a 3 spd is already pulling 1:1 while the 4 spd is still clunking through the gears...
Just a thought, wonderin if anyone has the solution.
James
James
Car: 99 Formula
Axle/Gears: 342
For around town sometimes it would be best for the tranny to leave it in D, if the it is shifting in and out of OD due to low speeds.
Engine: 383
next time I blow it out I'll have to try one, it will be about a month, by the way how much are they?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Just a side note, a 95 Supra TT Auto will only do 141mph in Drive.
Click the O/D on and you can go faster.
I was able to hit 155mph a few times before I ran out of road AND the car was still pulling hard.
Car: 99 Formula
Axle/Gears: 342
Originally posted by Mark A Shields
You're nuts!
You're nuts!
My goal is 200+ in my 86 Trans Am, I'll get there eventually.
Car: 91 Z28 Convertible
Engine: 305TPI
You think?
You think?
*pictures coyote strapping a rocket to his back*
maybe more a hypothetical..
Certainly not related to the original 3spd vs overdrive,
but Zepher, do you really feel that you'll pull 200+ with all that extra sound-system weight?
One of the most ridiculous parts about Fast and the Furious (other than the makes/models of cars?
) was all those guys racing with under-chassis neons and a set of 12s...
or is it not enough to make a significant difference?
James
) was all those guys racing with under-chassis neons and a set of 12s...or is it not enough to make a significant difference?
James
My sound system isn't that much, I've got one 12" JL 12W6 in a small box and 2 small amps in a small amprack and my JVC headunit.
For a top speed run, weight isn't the main concern, it is drag coefficient, lots of horsepower, and gearing.
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
You are correct maverick544 and you can almost always just put 'er in OD and drive. I downshift to Drive when going down long hills (especially my local speed trap) or when I'm driving in the mountains.
rubblerubble
Mar 13, 2016 06:57 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
