Question about proper bolt torque
Old Apr 22, 2002 | 10:03 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I am using 3/8 bolts on the caliper mounting plate. I calculated that at 40 ft?#'s there is more than enough pressure to keep the spacers from moving (between the axle flange and the caliper mounting plate. The service manual says to torque them to 74 ft/3's though... so I did. I had to remove the bolts and found little pieces of metal shavings on the bolt. Am I tightening the bolts too much? They are grade 8 so they should be able to take the abuse. I am just concerned that I am actually over torquing the bolts.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
