Heat soak
Old Apr 23, 2002 | 09:48 PM
SlowStangEater's Avatar
Heat soak (what the Heck are the symptoms)
OK I know my heat soak posts are getting old but Im still confused to the exact symptoms of heat soak. Here is what I know.
SYMPTOMS:
1. Car wont start after it gets hot (usually from stop and go driving)
2. I can pop the clutch to start it.
3. I can wait till it cools down.
But heres what I need to know. When heat soak happens are you supposed to be able to jump start it or not???
Old Apr 24, 2002 | 09:34 AM
Vader's Avatar
SSE,
If the failure to start after heat soak is becasue of a starter solenoid problem, jumping it to start may not solve the problem. If the engine will crank well after heat soak but not fire, you have a compression/fuel delivery problem.
What are the exact symptoms, since I didn't see the other posts?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
