Which MAF to BUY
Old Apr 24, 2002 | 01:17 PM
Prem's Avatar
Which MAF to BUY
Hi I need to replace My MAF sensor on a 87 GTA 350 TPI. I would like to buy the Wells Manufacturing version. Is this a good idea?
My concern is with the MAF burn off relay, will that still work with it. And also will I have to make any other adjustments to the engine.
Prem.
Old Apr 24, 2002 | 03:36 PM
iroc22's Avatar
It's suppposed to be a straight drop in MAF.
SU-145
ImportsRsloths has a mail order outfit that you can get it for $166
Old Apr 24, 2002 | 08:27 PM
89Irocz23's Avatar
Wells is good
I have the wells and its so much better than the other pos I had. (Bosch) Also I think the Wells flows more, but I didnt notice anything I just noticed it runs a lot smoother. Oh ya and the wells has a lifetime warrenty so thats good.
Old Apr 24, 2002 | 09:03 PM
Prem's Avatar
What about K&N
Thanks alot. I will go ahead and order it. Should I also go for the K&N filter? If yes can you explain What I have to get, straight filter box remove and replace or it is more complicated.
Prem
Old Apr 24, 2002 | 10:09 PM
89Irocz23's Avatar
well im not sure since you have a GTA maybe some one who has a GTA, but if was you I would make a cold air intake or something. Look in the tech articles to get some idea, but i think they make a K&N of some sort for ur stock air box.
Old Apr 25, 2002 | 10:59 AM
Vader's Avatar
Prem,
If your '87 still has the "garbage can" air cleaner assembly at the right front corner of the engine compartment, you can use the K&N stock replacement air filter. The k&n P/N is E-0890. It fit my '86 TA perfectly. If you feel that will still be a flow problem, check this article: Air Flow.pdf
You'll need Adobe Acrobat Reader to view/print the file (see link below).
BumpaD82
Feb 26, 2016 02:57 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
87hellbird
Sep 14, 2015 05:08 PM
