what the hell my rpm's not going up?
Old Apr 25, 2002 | 02:33 PM
cridom's Avatar
when im doing a burnout my rpms dont go more than 4000
why?
my car its pretty overheated sometimes
with a tune up would this be gone?
my car wasnt like this before
and its not accelerating as much as before
Attached Thumbnails what the hell my rpm's not going up?-sin-t-tulo-1
Old Apr 25, 2002 | 02:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You're TV cable might be misadjusted causing early shifts. Does it happen even when you don't powerbrake.
What do you mean overheated sometimes? what temp.?
Old Apr 25, 2002 | 02:45 PM
ORAY777's Avatar
Shouldn't let your car overheat man. I would check your thermostat and check your water level. Also check if your fans are turning on. Let the car idle and let it warm up at around 220 degrees or so the fan should kick on if it doesn't then probably your fan coolant switch will probably need to be replaced. All you have to do is disconnect the wire to the switch and ground it and the fans should kick on. Maybe you got a clogged convertor thats why it won't your rpm's won't go so high. I would check that. Excessive backpressure probably. Just a quess though.
Old Apr 25, 2002 | 04:43 PM
Chronos_Titan's Avatar
What engine do you have? Some info like that is useful.
Old Apr 25, 2002 | 05:29 PM
Car: 99 Formula
Axle/Gears: 342
True, but I think a lot of people who don't know 3rdGens very well, don't know that these cars were designed to run a little on the warm side, so in fact he might not be overheating.
Old Apr 25, 2002 | 07:07 PM
Hulk0202's Avatar
The engines run hotter for emissions purposes. You dont want it to run hot, that robs power. If your on a completly stock motor, and your trying to sit there and do burnouts..........maybe that has something to do with the problems your having.
Old Apr 25, 2002 | 07:21 PM
Car: 99 Formula
Axle/Gears: 342
The engines temp shouldn't have anything to do with the way the car is shifting.
Try the tv cable adjustment and get back to us.
Old Apr 25, 2002 | 08:35 PM
cridom's Avatar
sorry im new and 1 of the 2 fans is not working and i have a 195 stat and its completly stock and like 2 month ago the rpms were normal not low and my temp is around 220-260 sometimes reaches 260 and also i dont do too many burnouts and i wont do it but i remembered that when i did it a couple month ago the rpms went so high that i had to lift my foot a little bit
and if i do the burnout rpm wont pass 4k if im pressing the gass all the way
how i replace the fans or how can i know if its ok i know its not runnig cuz i drove for like 20 min then i opened the front and 1 fans was running not 2 and should i get a 180,160 stat?
1991 camaro z28 5.0 v8 305 tpi t-top
Old Apr 25, 2002 | 08:38 PM
Car: 99 Formula
Axle/Gears: 342
If I'm not mistaken the 2nd fan should come on with the AC or when the temps reach 220*.
I would not be driving that car running 260* that's reaching dangerous temps.
I'd get a 180* stat and fix that other fan.
Old Apr 25, 2002 | 10:10 PM
Hulk0202's Avatar
The second fan is for the ac. It sounds like a clogged cat. The same thing happened to me. The car would drop on its face if I tried to floor it. I couldnt get over 3500. This also causes a surplus of hot exhaust that heats up the engine. Try removing the cat and see if it fixes the problem. Good luck
Old Apr 26, 2002 | 06:03 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Tune-up maybe? I would check the easy stuff before I start dismanteling the exhaust....if you must, smack the cat with a rubber hammer, do you hear stuff falling?
Is your air dam still there ?
Old Apr 26, 2002 | 06:57 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Man are those run-on sentences or what?
I would try banging on the cat with a rubber mallot, if you hear some bits rattling off in there, then the cat is more than likely bad. Also, it sounds like your car may need a basic tune-up.
I hear you Mark, but it sound like this car has never been touched before, maintenance wise. If you know what I mean.
Drive it like you stole it.
Old Apr 26, 2002 | 07:31 AM
Car: 99 Formula
Axle/Gears: 342
That's a very good point.
Back to what you said about it running hot?? How hot are you talking?
Old Apr 26, 2002 | 10:07 AM
cridom's Avatar
sorry for my ignorance but where is the cat are the tube before the mufller and all the rest down to the 2 pipes? and my temp its always 230-240 but if i accelerate gets up to 250-260
thanks for all
Old Apr 26, 2002 | 11:12 AM
TBI305Camaro's Avatar
hmm sounds like somebody needs to hang out on the board more often so they can learn. i knew nothing about cars at all before i got my camaro and started hanging out here...im still new but im pretty confident about most of the stuff i do
Old Apr 26, 2002 | 12:35 PM
ORAY777's Avatar
Kind of looks like a big eggshell after the Y-pipe should also have a small diameter pipe leading into it from the Air Injection system.
Old Apr 26, 2002 | 03:28 PM
Car: 99 Formula
Axle/Gears: 342
Or almost like another muffler right after the y-pipe.
Old May 2, 2002 | 09:32 PM
cridom's Avatar
help!!!!!!!
now my auto transmition is not shifting till 6500 rpms or so sometimes its ok but also when i accelerate sometimes the rpms go up but the car moves not too much why???????????
305 tpi 5.0 or 5.7 v8
thanks
Old May 2, 2002 | 09:56 PM
onebinky's Avatar
sounds like you fried the clutch packs (I think thats what they are called) in the transmission. Time for a rebuild
Old May 3, 2002 | 10:37 AM
Engine: 406
might try your TV cable..but it sounds like a bad tranny to me also..
Old May 5, 2002 | 04:16 PM
cridom's Avatar
hey
i dunno y but i took out the fan and i tried it and it was ok it works but when i install it its doesnt work!!!!!!! why???? help please
the thing about the rpms it happens that when i accelerate sometimes is like if i were pressing the cluntch (i know its not good spelling i meant the 3rd pedal to the left in manual transmitions)so i kinda accelerate but the car doesnt move and if i press all the way down the car kinda launch like a rocket y?????
any pics of cat-backs?????????????? please
Old May 6, 2002 | 05:23 AM
Engine: 406
I must say you have me confused... . If you push the clutch in all the way the car launches?????? as for the picture...
I thought you had an auto transmission
Old May 6, 2002 | 10:29 AM
cridom's Avatar
i meant that feels like if u were in a manual tranny pressing the clutch it feels lkike the rpms go up and the speed doesnt change its like when u accelerate and press the clutch in a manual but mine is auto did u understand
im not american sorry
please help
how much hp would hooker catback give me
good sound right
Old May 6, 2002 | 11:05 AM
Engine: 406
sounds like your tranny is slipping, have you checked the fluid level? These 700r4 auto's are very sensitive to the proper level. As for the hp increase, I hear 10-15hp increase, But that depends on your set-up. I think I would get that tranny looked at first....that would also cause your car to run warm (slipping)
Old May 6, 2002 | 11:49 AM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Just a suggestion. But you should probably stop beating on the car (burnouts, break torques, reverse to lows, etc.) until you figure out what's wrong with it. Another reason you maybe over heating is that you just sit there and do burnouts all day and never get any air through the radiator at higher speeds.
If you want the car to last don't beat it. These cars are designed to be driven hard, NOT to be pounded to ****!!!
Or I could be totally wrong?
Old May 6, 2002 | 01:52 PM
Engine: 406
OUCH!!!!..Now that wasn't very nice......His $, His car......"America"
You can do anything you want to your car.
You sound like your Daddy!!!! or I could be wrong......:lala:
Old May 6, 2002 | 02:17 PM
Car: 1991 Formula
OK my bad. Sorry, but I have heard a few people this weekend cry about how crappy their car is because it breaks all the time. But when it's not broke all they do is beat it, None stop. So if you are doing burnouts alot and you need help with a problem fine.
But if your doing burnouts all the time and are mad at the car for breaking something then I retract my apology, Sure it's your $ but I hate to hear people bad mouth cars for being junk when they treat them like junk.
Old May 6, 2002 | 02:23 PM
Car: 99 Formula
Axle/Gears: 342
I agree, but I've been told several times that power braking isn't bad for a car. :nono:
Old May 6, 2002 | 02:36 PM
Engine: 406
I hear ya...I run my Car Pretty Hard ...but I also take care of it. . And "I' pay for it when "I" break something.....Hell I'm 40yo and still drive like I'm 16. Have a great day
Old May 6, 2002 | 05:40 PM
cridom's Avatar
hey
sorry but i did it 2 times and it was ok cuz after that i felt bad about the tires so im not doing it again and thats the only thing i do
when im acceleration to full speed is it faster if i press the gas little by little of all the way in one time and hold it? maybe thats why i ****ed the tranny i dunno this happened 2 days ago like on sunday..
thanks and im 17 im working to get upgrades my father only bought the car for me 3k (well thats a lot for my father to give me) is it a good price for a 5.0L v8 305 t-top?????
Old May 6, 2002 | 05:51 PM
jasonbennett's Avatar
take your car into have the tranny looked at. you just might need a new torque converter but i would opt for a total rebuild, and a new torque converter with more stall. look for the air dam in front of you car directly under the radiator support. if you don't have one them get one and see if it still gets hot. if not them replace your cat. it loos like a long tiny muffler with a little pipe going into the side. it will be under the car at the fender/door space om the passenger side.
Old May 6, 2002 | 06:15 PM
onebinky's Avatar
on a stock or close to stock car, powerbraking puts a huge load on the torque converter, and it's also not so good for the other drivetrain components.
Matt
Old May 6, 2002 | 06:57 PM
cridom's Avatar
thanks!!!
today im buying a 180 stat !
any recommendations for the cat ? hard to installl???
also what could be causing my fan not to turn on the fan its ok i tried it direct and it worked but when i instal it it doesnt work even at 220 degrees and its the one in the coolant tank side is that one the ac?
im trying to get the hooker catback,new cat,sfcs and megashifter and paint work that all ill do with my car and maybe new headers any recommendation for the headers ? price? thanks
Old May 6, 2002 | 07:06 PM
Car: 99 Formula
Axle/Gears: 342
Headers, either Hooker or Hedman, about $300 or so. Not sure which but I think one doesn't come with a y-pipe, you'll need one. Get a Catco cat from www.summitracing.com , it's hi-flo and not that expensive.
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
Stroopwafel
Sep 11, 2015 06:38 AM
dimented24x7
Sep 6, 2015 03:51 PM
