Guide plates and screw in studs
Old May 5, 2002 | 07:03 PM
3gc's Avatar
3gc
Car: Z28
I bought vortec heads that were machined for screw in studs and guide plates. But I just realized I can't use the guid plates because I'm using self aligning rocker arms. Do I put spacers the thickness of the guide plate under the stud when I put the studs in or will it be fine without them. I installed the studs and it didn't bottom out. I'm wondering because I did a search on the boards and found out they machine .4" from the the stud boss. I got ARP screw in studs, Do I need longer studs or something?
Thanks for any help.
Old May 5, 2002 | 09:23 PM
ede's Avatar
ede
if the studs are the same as the ones i've used from arp there is a radius under the hex and a larger unthreaded diameter that will keep the stud from fully seating. on mine i just used a cheap set of guide plates and cut the part the push rod goes through so the studs fit correctly. a washer most likely would of done the same thing.
Old May 5, 2002 | 09:49 PM
3gc's Avatar
3gc
Car: Z28
I already have the guide plates so I guess that is an option but I was hoping I could get my money back on them. It looks like the hex part of the stud is flat against the head. If it isn't, it's at most like 1/16 off of it. I torqued them down to 55 ft. lbs. and used assembly lube on it like the instructions said.
Old May 6, 2002 | 07:08 PM
3gc's Avatar
3gc
Car: Z28
I called up the place where I bought the rocker arms and I'm going to send them back and order Harland Sharp roller rocker arms. I'll save about 70 bucks including shipping, so I'm happy. That's money for the water pump.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
6speedIROC
16
Mar 15, 2023 08:33 PM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
