What 2nd gen parts are interchangeable with 3rd gen?
Old Apr 25, 2002 | 05:27 PM
fattie92's Avatar
i have access to a 81 firebird,, what all is interchangeable on these cars?
Old Apr 25, 2002 | 05:50 PM
Fast3rdGen's Avatar
i don't think anything will interchange without some modification.
Old Apr 25, 2002 | 05:51 PM
fattie92's Avatar
damnnnnnnnnnnnnn
Old Apr 25, 2002 | 07:12 PM
ChevalierSS's Avatar
...the motor. That's about 95% of the interchangeable parts.
Old Apr 26, 2002 | 12:44 AM
Jza's Avatar
Jza
And even then only if it happens to have the Chevy 305 instead of the Pontiac 301.
Old Apr 26, 2002 | 12:49 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
it would be intriseting to have the poncho 400 or the olds 403 in a thirdgen, but it would need just alittle work to get it to fit also the tranny will fit in an 82 that had a TH200c and you might be able to salvage the wheels
Old Apr 26, 2002 | 01:06 AM
fattie92's Avatar
sweet i can use them wheels to throw slicks on!!! good thinking!
Old Apr 26, 2002 | 11:26 AM
capn_crash84's Avatar
Will a 400 out of a 79 trans am fit? I bought it already, but i havn't picked it up yet. I hope it will, or i just wasted my money...
Old Apr 26, 2002 | 02:51 PM
82camaro's Avatar
Car: 82 camaro SC
400 pontiac in a 3rd gen will be a tight fit but you can make it work. You will need figure out how to mount a pontiac engine to a 3rd gen, could be fun since a 3rd gen never had a pontiac engine. Also the tranny will need an adapter plate or be replaced. Pontiac has a different bolt pattern.
Old Apr 26, 2002 | 04:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I believe that a Pontiac engine will mount in a 3rd Gen no problem as long as there's room for it. It's the trrans/engine interface that might give you trouble. Unless you go with either a non OD automatic or a manual. The exhaust manifolding might be a problem too.
Old Apr 26, 2002 | 04:43 PM
whats a good transmision to use that will bolt right up? I'm not attached to the 700r4 at all, especialy because my mechanic said it would be more expensive to rebuild because it has more parts. I don't want to convert to a manual. Overdrive would be nice, but i could live with out it. Thanks
Old Apr 26, 2002 | 04:55 PM
fattie92's Avatar
what about the seats?? i can get a good interior very very cheap... will it go right in??
Old Apr 26, 2002 | 06:45 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Please don't take my word as gospel. I'd hate for you to come to CA gunning for me after you tried and failed to wedge that Pontiac in there.... Do some homework first.
I'd first check to see if the 2nd Gen Pontiac motor mount is the same as the mount for a 3rd Gen F-body. Or at least check to see if the 3rd Gen motor mount will bolt to the Pontiac engine. I've seen a few SBC's swapped into 1st Gen Firebirds. Since the SBC is the common thread across all Generation F-bodies, and the Pontiac was seen in both 1st and 2nd Gen F-bodies, it's a good bet the Pontiac will fit in a 3rd Gen.
Most any B-O-P (Buick-Olds-Pontiac) patterned TH-350 transmissions will fit. Tail shaft length might limit your choices and whether or not the 3rd Gen will allow for moving the cross member forward or backwards. I think B&M makes a kit for fitting TH-350's in place of TH700's.
I'm starting to miss my 389 Tri-Power......
Old Apr 26, 2002 | 06:53 PM
fattie92's Avatar
will the seats work in my thirdgen?
Old Apr 26, 2002 | 11:38 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Remember, the PONTIAC engine is a LOT heavier than a sbc. I was going to use my built pontiac 406 in my GTA, untill I lowered it into the chassis. Custom headers is about the only choise for exhaust. I think the mounts is no problem, you just have to remove the stock mounts and drill new holes in the frame. There were some 200s that fit the bop bell housings. The seat track won't fit the 3rd gen, but you may be able to bolt the 3rd gen tracks to the 2nd gen seats.
Old Apr 27, 2002 | 12:44 AM
fattie92's Avatar
hmmmmmmm....interesting
Old Apr 27, 2002 | 04:28 AM
Engine: 383
some TH 350's have a dual bolt pattern that fit's all of GM's engines.
Old Apr 27, 2002 | 04:57 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
THEY DO MAKE AN ADAPTER PLATE TO MATE A CHEVY TRANNY TO A PONTIAC ENGINE
JEGS CARRIES IT
redmaroz
Aug 16, 2015 11:40 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
reiderz iroc
Aug 13, 2015 04:57 PM
ChevyZ71
Aug 13, 2015 07:30 AM
1nastygta
Aug 8, 2015 07:38 PM
