Please educate me about fuel pumps
Old Apr 25, 2002 | 06:08 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
All these questions refer to an 89 IROC L98 and a 92 Firebird (V6). What type of in-tank fuel pumps and in-line fuel pumps can our cars use? If your in-tank fuel pump does not work, can you put in an inline pump and not worry about the in-tank? What brands of pumps are recommended? What flow-rate of a pump do you need for a 400HP N/A and 550HP N2O engine? What about flow rate for a stock V6?
I've heard putting an in-tank pump is a PITA, what all is involved? Why go through the trouble of the in-tank, is it better?
What r the pros and cons of an inline vs. and in-tank?
A lot of questions, but I know zero about this, never had to do it before.
Old Apr 26, 2002 | 06:08 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
ya gotta take the old pump out of the tank..the fuel wont syphon through it.....
Old Apr 26, 2002 | 06:52 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Riley is correct. In tank pumps are used because the pump can be realistically sized. The pump will have to be larger to siphon from the tank if it is outside. For example many pickup trucks use as many as THREE pumps. A Ford f-150 with a V-8 uses two in tank pumps(if it has dual tanks) and one inline pump. Also a benefit of the in tank is that the fuel will cool the pump and extend it's life. If you are going to replace it I strongly recommend using the AC-Delco OE, have heard way too many horror stories about aftermarket junk. If you want to play around with fuel delivery get an adjustable fuel pressure regulator.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
