Red Fluid in Radiator Resevoir?
Old Apr 24, 2002 | 08:06 AM
dps8315's Avatar
Guys,
Looking at an '89 TBI 305 from a guy that didn't know the difference between a TPI and a Carb setup. He also had the car painted without having good body work done, and he also would rather drive his 85 Honda... but whatever.
The car has 120,000 miles on it, which doesn't bother me because honestly the engine compartment looks like it has half that many. I see the car daily and it's been sitting all winter, but the few times he had to drive it, it started right up and away he went.
The only thing that worried me is this thin, red fluid (tranny?) in the radiator resevoir... which was deathly low. Before I test drove it I asked him if he had any radiator fluid...and he did, and we filled it up with the GREEN fluid
Anyway the car didn't run hot or do anything funky... will a standard flush and fill take care of the problem?
I really want this car!
James
Old Apr 24, 2002 | 08:33 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yeah, that's tranny fluid, though it shouldn't be in there. Tranny fluid passes thru the radiator (I believe) so I'm not sure how it got in there.
Old Apr 24, 2002 | 08:34 AM
chevyracing's Avatar
check the fluid more carefully, it could be premixed radiator mix. Some of the premixed 50/50 solution you can purchase is red. The tranny cooler could be leaking into the radiator by highly unlikely.
John
Old Apr 24, 2002 | 08:41 AM
82camaro's Avatar
Car: 82 camaro SC
Could be dexcool coolant. You shouldn't mix dexcool and regular green coolant. Dexcool is better stuff IMO, it lasts 100000 miles and transfers heat better.
Old Apr 24, 2002 | 08:55 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Well, if the tranny cooler is leaking into the radiator (which can and does happen), the opposite is also likely happening, and the tranny should be considered dead.
Or it could just be rust, or dexcool, or something else funky going on.
I know, not much help, but we can't guess what it is based on the description of 'red in the radiator', so there are your options.
Old Apr 24, 2002 | 09:28 AM
dps8315's Avatar
Guess I could've used an anti-freeze tester before we put extra coolant in there...but I dont carry one in my back pocket....
most of the time
the radiator looked brand-new... I guess I'll check all the lines. The car shifted fine. Maybe I'll just ask what kind of coolant he had in there before
Thanks for the input
James
Old Apr 24, 2002 | 10:00 AM
Car: 99 Formula
Axle/Gears: 342
Isn't dexcool and those other kinds orange though and not red?
Old Apr 24, 2002 | 10:06 AM
Greg Kuhlmann's Avatar
I'm going to say its the dexacool... our 97 chevy truck takes it... its coolant just not the right kind for our cars... i would flush it and fill it up with the "Green Stuff"..... there has to be something different about the dexacool... it doesnt make sense for someone to put tranny fluid in there... when at the auto store the dexacool is right by the "green" coolant...
Flush It!
Old Apr 24, 2002 | 11:37 AM
Vader's Avatar
If you're afraid that it is transmission oil in the overflow reservoir, let the car sit for a couple of days and see if the oil separates from teh glycol (they aren't soluble in one another). If it IS transmission oil, there should be a distinct layer of red oil above the coolant mixture.
I'm guessing it's DexCool or an additive, or a really rusty cooling system. In either case, a thorough flush is a good idea on a used car purchase, along with a lot of other routine maintenance.
In my experience, many of these Honda drivers have the mentality that since the car will "run forever" as the advertisements and Consumer Reports propaganda imply, no maintenance is ever required, and therefore do no maintenance. So be ready to catch up a bit. And 120,000 miles may not be a lot if the car was maintained.
Old Apr 24, 2002 | 04:21 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Not meaning to state the obvious, but have you checked your tranny fluid level? (Make sure you do it while motor is running)
Old Apr 24, 2002 | 06:17 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i'm with vader. dexcool mixes with water as does glycol so if you put dexcool in glycol they'll mix and will be uniform in color, not seperated
Old Apr 24, 2002 | 08:48 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I'm also with vader, I run dexcool and that stuff works great, I can go up to the Indan Springs airstrip wich is 45 min away (with me driving) and with my A/C at full blast, and my engine temp dosent go past 180 degrees on my digatal readout. but anyways it is red in my resovware(sp) and IT CAN NOT be mixed with the green stuff- it will soldify at high temps in narrow passages flush the sys immeaditly and by the way most dexcool is pre-mixed so look before you add water
Old Apr 25, 2002 | 12:31 AM
dps8315's Avatar
Now there's some advice...
I feel MUCH more confident about the used car situation now. After going over the rest of the vehicle again, if I decide to buy I'm confident that the cooling system will be in working order. The tranny fluid level looked alright, but it wasn't really sufficiently warmed up for the best reading.. I'll give that one another shot.
The car looks very well maintained, thus my interest in it... that "red stuff" just through me for a loop.
There does seem to be a little bit of conflict with regards to whether or not Dexcool is a suitable alternative to standard glycol... I've also seen people run "water wetter" with straight water during the summer... Any feelings on which of these options offers the best cooling performance?
If there's a general consensus I'd rather not waste too much time a/o money trying 'alternatives' that don't work..
Thanks a million
Old Apr 25, 2002 | 05:48 AM
Car: '87 Camaro LT
Engine: 355 L98
hey 84 Z-28 350,
work ever take you to area 51 lol? *insert eerie music here*
Old Apr 25, 2002 | 07:27 AM
82camaro's Avatar
Car: 82 camaro SC
Water wetter and straight water is a race only item, IMO. Because of the corrosion that takes place. Dexcool is the standard stuff in GM vehicles from mid/late 90's to current. It works great and lasts a long time. No complaints here since I installed the stuff in my 82.
Old Apr 25, 2002 | 09:16 PM
Engine: 383
no, I havent been to groom lake, they dont even let the pilots fly over there, but I have been to allot of the other faciltys on base (which by the way is 300 million acers- it takes 10 hrs driving at 75 mph to reach the NE corner).
Old Apr 25, 2002 | 11:31 PM
FAST85Z28's Avatar
hey that "red" stuff is supposed to be the best and its not trans fluid.. (well could be, but i dont think so) that "red" stuff should last like 7 years or something.. and maybe when he filled it up he didnt have the expensive stuff and just had a bottle of "green stuff"
Old Apr 25, 2002 | 11:37 PM
dps8315's Avatar
So dexcool it is... I'll definately have to try it in the other Camaro too... That one heats up to the GM standard 230
Woo that's scary
James
Old Apr 26, 2002 | 12:28 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Nope.
WW and H2O is a "non freezing conditions only" item.
The cooling system needs some kind of anti-corrosive mixed w/ the water, and the WW (or 40 below, or RMI-25) fits the bill.
I have run WW or 40 Below w/ distilled during non freezing season here for 3 or 4 years. Many Buick guys swear by water & RMI-25 (some of whom are in Phoenix)
The worst corrosion I've seen was in my 87. Prior owners (in Kalifornia) used straight water. Nothing else. Not that it matters now that the engine, rad, water pump, and heater core and anything coolant related has been changed, but man was that thing full of rust.
Matthew
Old Apr 26, 2002 | 12:50 AM
Jza's Avatar
Jza
40-below shouldn't be mixed with coolant (dexcool et al), should only be mixed with water. Says so on the back.
Old Apr 26, 2002 | 01:38 AM
poncho9789's Avatar
The only really special things about dexcool is that it doesn't corrode aluminum parts as bad as glycol based anti-freaze. And insted of it lasting 3 years it last 5 years. It is a good coolant that is every bit as good (even better) as your standard "green" coolent that is normally used. It does have the down side of being about $8.50 a gallon.
Old Apr 26, 2002 | 07:16 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Aluminum corroding?
Old Apr 26, 2002 | 07:48 AM
TBI305Camaro's Avatar
what is up with GM running our cars at 230??? and 0* timing...damn emmissions my car runs 160 and yes it goes into closed loop. runs good and i feel better that my car is staying cool instead of running 220ish
Old Apr 26, 2002 | 07:52 AM
jmd's Avatar
jmd
Originally posted by StngKlr
Aluminum corroding?
Ever seen an intake rot around the coolant passages? I sure have.
Matthew
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
92firebirdguy
Sep 1, 2016 07:53 AM
gta892000
Sep 16, 2015 12:37 AM
Numbah-1
Sep 12, 2015 08:57 PM
