Key Switch not turning back to off!!!
Old Apr 25, 2002 | 10:22 PM
86IROC350NY's Avatar
Hey
I am taking my car to a locksmith who was a mechanic on friday, but if he can't help I have to bring it to the chevy dealership.
My key switch is busted and I can't turn my car off. To turn it off I just unplug the distributor and then unhook the battery to shut off the fan.
What do you guys think?
--Dan
Old Apr 25, 2002 | 11:25 PM
cdogc350's Avatar
if you have a auto-trans there is a switch that doesnt let you turn the key to the lock position unless your in park. many times it moves to where the switch isnt able to engage while in park, thus the key cannot come out. check this, i would bet on it
Old Apr 26, 2002 | 06:29 AM
manual tranny
Naw,
Its a manual. I have been holding down the clutch and I keep it in neutral when I do it. It just started a little while ago.
Thanks though!!
--dan
Old Apr 26, 2002 | 09:41 AM
iroc_one's Avatar
Does the radio and other accesories stay on too?
Don't know if its the same piece or not, but we just fixed a beretta that did the same thing. Thought it was the ignition lock cylinder, but it turned out to be the piece that connected the lock cylinder and the rod that goes through the ignition switch on the coloumn.
It would let the car start but wouldn't turn back off. Part cost $28 at a GM dealer.
Good luck
Old Apr 26, 2002 | 09:51 AM
EXACTLY
You hit it. That's what people have been telling me. I can start it but not turn it off. The bad thing is that I don't have the key for the steering column to open it up...the car was broken into and the steering column was replaced by a boneyard F-bird
--Dan
apo_bailon15
Mar 28, 2016 05:20 AM
tnrednneck
Aug 13, 2015 08:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
ZsTransAm
Aug 11, 2015 07:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
