How hard is it to remove the "drive" speedometer gear from the trans??
Old Apr 26, 2002 | 11:27 AM
CamaroX84's Avatar
The other day I took out my "driven" speedometer gear to see what I had. Now I know I need a different "drive" gear to make mine right. It's a 700R4 transmission with a cable-driven speedometer. I'm getting the new gear today so I was wondering what I have to do to remove/install the drive gear before I go out and do it. Thanks in advance.
Old Apr 26, 2002 | 12:40 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
https://www.thirdgen.org/newdesign/t...eedogear.shtml
Old Apr 26, 2002 | 10:33 PM
Jza's Avatar
Jza
It's pretty involved for so simple a part. You have to remove the driveshaft, disconnect the torque arm from it's mount, disconnect the cat converter hanger and friends from the tailshaft, remove the driven gear, remove the tailshaft, take a tranny fluid bath, wrestle with that little clip, then attempt to remove the drivegear without resorting to flat out smashing it off the output shaft.
Old Apr 27, 2002 | 12:04 AM
CamaroX84's Avatar
Well, I got it all apart, and I started putting on the new drive gear. Sure enough, right as I had it almost all the way on, I hit it too hard and cracked the gear right in half. So now I have to wait until Tuesday or so til I can get another gear. I'm just going to use my broken gear as a piece to hit with the hammer instead of hitting the gear directly.
Old Apr 27, 2002 | 12:34 AM
Jza's Avatar
Jza
Yup. Murphy strikes again. Lubricate it with a generous coating of petroleum jelly (inside the gear and outside the output shaft) before you install it. That'll help some.
Old Apr 27, 2002 | 09:08 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
First Boil some hot water
Turn off heat
Thow gear in the hot water
Wait a few minutes for thermal expansion to occure
Quickly put retainer clip into Groove in the gear
slide Gear on tailshaft (while it's still hot) to clip-hole closest to valvebody Sorry , burning your hands may occure, use a rag to handle the hot gear
If you clip it on the wrong hole, Don't try to force it out when it's cool! It'll break!
Use a hot water rag to expand the gear again and start over.
Be careful not to leave water drops in the trans , wipe the tailshaft and coat with some trans fluid.
Good Luck,
Eddie
Old Apr 28, 2002 | 02:52 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
http://www.sethirdgen.org/vss.htm
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
