question about speedo cable drive gears on a manual trans
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i just put a new speedo cable in my car and its about 5 miles per hour fast. if i replace the drive gears will this bring everything back to normal. it still has the same 373 gears in it (never changed them). also do i have to get the drive gears for gm or a parts store. when i pull the drive gears out will trans fluid come out. thanks for any info.
Car: `86 SS / `87 SS
What tooth count do you have on the driven gear? & What colour is the drive gear (check w/ flashlight)? I can get you the right ones; just need to figure out which ones you have already.
Matthew
Matthew
Car: 84 camaro Z28
Engine: 434sbc
do you just put new ones in or do you buy new unit. i'll check the that out on monday or tuesday. depends on what time i get home from school. thanks alot. also how much will this cost.
Yes, there'll be a bit of fluid. Just jack up the rear of the car instead of the front to minimize that, and undo the 8 or 10mm(?) bolt to release the retainer of the driven gear.
1992 Trans Am
May 10, 2023 07:19 PM
dhonda200
Aug 11, 2015 11:50 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
