No start, please help
Old Apr 26, 2002 | 06:17 PM
MILT's Avatar
I'm begging here, I'm at wits' end.
I recently installed a new steering column, and the car won't start. I've installed a different ignition cylinder, so VATS doesn't match up. I burned a new chip w/o VATS, but it won't start.
The computer kicks out a code 53.
What else should I look for? Could the NSS be bad or disconnected somehow.
PLEAAAAAAAAAAASE help.
MILT
Old Apr 26, 2002 | 07:53 PM
MILT's Avatar
once again, thanks for all the help.
Old Apr 26, 2002 | 10:11 PM
Vader's Avatar
Milt,
Hang in there, bud. We don't all live here 24-7.
"Won't start", meaning it won't crank, or cranks but won't fire?
Old Apr 27, 2002 | 10:28 AM
MILT's Avatar
I'm sorry for being impatient, but this has been going on for over a week, and I need to get it figured out...
Okay, here's the deal...
Everything works, but no crank. Car is '91 Formula TBI. I replaced steering column and the problem arose (no start, code 53). Then I burned a chip w/o VATS (also tried VATS bypass) but that didn't work.
I've read in previous posts about disconnecting the VATS connector from VATS module and connecting some of those wires, but I can't find out where the module is (i.e. center of dash is too vague--do I have to take the entire dash off, vents off, etc).
I've also read about a starter relay "jumper." I have not been able to figure out from the posts which wires should be either connected or grounded.
So, I'm stuck with two possible solutions that still remain mysterious to me.
Any help or opinions would be greatly appreciated.
Thank you,
MILT
Old Apr 29, 2002 | 10:11 PM
Vader's Avatar
Sorry, butt I don't have anything for schematics on the VATS system. What does the SECURITY light do when you try to crank the engine? How about when you only turn the ignition to RUN?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
