will these runners fit my car?//
Old Apr 27, 2002 | 11:01 PM
TransAm87's Avatar
I have an 87 with cold start, will these SLP runnrse fit my car//what is difference with or without cold start..PLEASE HELP FAST
please go to page 4 of my site to look at hte runners
thanks
aj
http://www.cardomain.com/member_page...=180745&page=4
Old Apr 28, 2002 | 11:29 AM
Vader's Avatar
87,
Using those runners would require you to install a different PROM to eliminate the cold start system.
I'm not sure from the photo, but they look similar to the Edelbrock semi-siamesed runners. I know that those leave precious little space for the fuel injecctors and their connectors, and are only siamesed about 2" into the runners. They also have the same tube diameter as the stock runners at the ends, but are slightly larger between the flanges due to the blending of the runners. If the gaskets in the photo are stock GM or FelPro, that should be a clue as to the size of the runners. The stock gaskets and FelPro replacements are too small for even the stock runners, and since they appear to match the openings in the photo, your diameter is no better than the stock runners. (Stock runner tubes are 40mm/1.574", and stock gaskets are punched at 1.525" I.D.)
To paraphrase Johnny Cochrane, "If the stock gasket can fit, the runner is probably sh*t." ... or something like that.
customblackbird
Aug 15, 2021 10:16 PM
tazs2000
Jul 15, 2017 08:44 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
armybyrd
Aug 10, 2015 09:23 PM
