Small problem with idle
Old Apr 29, 2002 | 08:56 AM
IROCBOY's Avatar
I understand that if an engine idle "lopes" or idles high and low rapidly, and backfires from time to time that the problem is EGR, am I right?
Old Apr 29, 2002 | 07:40 PM
IROCBOY's Avatar
Old Apr 29, 2002 | 07:52 PM
Vader's Avatar
What year/engine/fuel system?
Old Apr 29, 2002 | 07:58 PM
IROCBOY's Avatar
a 305 TPI
Old Apr 29, 2002 | 10:28 PM
Vader's Avatar
It could be a leaking EGR. It could also be a different vacuum leak, IAC, PCV valve, throttle body deposits, and even an ignition (failing cap/rotor) problem. Unfortunately, the EGR is the most difficult to access on your engine.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
