Gross Hp of an LG4?
Old Apr 29, 2002 | 11:55 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Gross Hp of an LG4?
I know how much the LG4 came with with everything hooked up, but I was thinking, what would the maximum Hp be for a freed up LG4....
SO, does anyone know the Gross Horsepower rating of the LG4 ('84 in particular or any for that matter)?
Old Apr 29, 2002 | 12:13 PM
Damon's Avatar
I beleive it was 155HP for that year but check the board's tech info section to be sure.
Open up the air cleaner, rejet the secondaries in the carb, replace the laughable 2 1/4" exhaust with typical 1 5/8" headers and a 3" cat and cat-back, bump the timing up 4* over stock and I think you'd be knocking on the door of 190-200 HP without ever taking the valve covers off.
Yes, the stock stuff is that restrictive. I'm working on a nearly identical 85 Z-28 with the LG-4 right now, seeing how far I can push it. It now burns the right rear tire to the ground on a hard 1st gear launch and gives it another good scratch shifting into 2nd. Before it wouldn't even sqeak the rears.
Old Apr 29, 2002 | 01:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Gross" is a pretty good description of LG4 HP...
Seriously, the 155 number is net. Gross flywheel horsepower doesn't really tell you much, though. But, add about 25%, that's fairly close.
Old Apr 29, 2002 | 04:07 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Gross Hp is the engine w/o accessories or exhaust... the maximum you could get w/ completely stock engine...
The LG4 in '84 had 150 Hp and going by the 25% assumption it would have 187.5 Gross Hp... the single worst engine component would have to be the hilarious .350 lift cam...
Old Apr 29, 2002 | 05:17 PM
iroc22's Avatar
Im sure gross power of the LG4 would be over 200hp. Probably 210. I've seen 60's muscle car engines bench dyno'd and one of them made 80hp more than GM claimed!
Old Apr 29, 2002 | 05:44 PM
NTChrist's Avatar
No way the LG4 is at 200 gross. How much horsepower does it take to turn a water pump? How about an alternator? Putting the exhaust through the entire exhaust system will kill some hp, but were still not talking about an extra 45 horses.
Old Apr 29, 2002 | 05:48 PM
NTChrist's Avatar
BTW, 60's muscle cars were still rated in gross horsepower.
Old Apr 29, 2002 | 08:32 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the 60's muslce cars didn't lie as often or hardly ever as much as thought, it's just the way they posted the numbers. to long to explain. the LG4 test i have seen on a dyno went about 180 if i remember correctly. this was no accesories and with air cleaner and exhaust as gross was rated.
Old Apr 29, 2002 | 11:50 PM
iroc22's Avatar
I meant to say, that they made 80hp less than GM claimed. Sorry.
RazorN8
Jan 7, 2022 11:44 AM
podiatra
Aug 31, 2015 09:53 AM
ambainb
Aug 29, 2015 12:43 AM
Conv389drv
Aftermarket Product Review
Dec 12, 2000 12:46 AM
theformula
Nov 8, 2000 04:21 PM
