Griffin Rad parts came today- No wonder I was Overheating!!!
Old Apr 29, 2002 | 03:29 PM
GreenProStreet's Avatar
All the stuff for the install all cost about 1/2 of the price of a BeCool rad.
Here are some pics-
Attached Thumbnails Griffin Rad parts came today- No wonder I was Overheating!!!-p4290044.jpg
Another-
Attached Thumbnails Griffin Rad parts came today- No wonder I was Overheating!!!-p4290045.jpg
Old Apr 29, 2002 | 03:32 PM
I got the highest capacity cooler they had. It is self regulating, because as the hotter ATF gets thinner it flows more. Cool piece!
Attached Thumbnails Griffin Rad parts came today- No wonder I was Overheating!!!-p4290046.jpg
Old Apr 29, 2002 | 04:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
That's the same radiator I got, I just had a fan shroud added to mine.
Attached Thumbnails Griffin Rad parts came today- No wonder I was Overheating!!!-enginesmall.jpg
Old Apr 29, 2002 | 04:11 PM
WaynesRS's Avatar
I have to get a new radiator , Im thinking of getting a griffin .How hard well the install be ? ....Is it taller than your old stock camaro radiator ?
Old Apr 29, 2002 | 04:16 PM
Car: 99 Formula
Axle/Gears: 342
The stock radiator support cover was the only tricky part, since the radiator is thicker, my stock cover fit over it, but not all the way down. This new is perfect.
Oh, and the one I got doesn't have a drain plug.
Old Apr 29, 2002 | 04:56 PM
Doh! So did I... didn't even cross my mind!
As for the install... it doesnt look hard at my end, but I havent done any work yet. The cooler should be easy to install because it seems that I just have to cut, reflange the lines and stick on the supplied adapter, hard to soft line, and make a bracket to mount it on. The cooler comes with all the fixins for every application; I am just making a new bracket because I want the most air flow, and a good appearance.
Old Apr 29, 2002 | 05:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Drain plug? Who needs a drain plug to drip all over the floor and the frame and clog up with little particles of sediment so it takes hours to drain all the way? I take the radiator cap off, put the car on ramps, and slide under the front with a drain pan on my stomach, and a screwdriver in my hand. I undo the lower hose, and as I'm disconnecting it, I push the pan up to the radiator lower outlet. The whole rad drains in, oh, 30 seconds, no mess? Just do it on a cool motor so you don' t burn yourself!
Old Apr 29, 2002 | 05:35 PM
NTChrist's Avatar
Originally posted by GreenProStreet
Another-
Oops! Flattened rad fins already! Time to get the straightener out...
Old Apr 29, 2002 | 06:08 PM
89ProchargedROC's Avatar
what was the total price on that bad boy?
Old Apr 29, 2002 | 07:29 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Was you able to use the stock radiator cap or does it require a special cap for the griffin radiator?
Old Apr 29, 2002 | 07:34 PM
Car: 99 Formula
Axle/Gears: 342
Mine radiator cost $180, yeah, loosening the lower hose works just as well.
Old Apr 29, 2002 | 09:52 PM
WaynesRS's Avatar
I dont know that I could get one of those to work on my car . I have a V6 , on ya'lls cars your upper hose is on the drivers side and your lower on the passenger side , mine is the opposite Or do you think this would work somehow . What do you guys think ? I might try to get me a new radiator in the next few days . ....I thought about getting a junkyard one , but my luck Id get a crappy one .
Man , I was just thinking ya'll , Im ganna have like almost new EVERYTHING on my car now hehe . New engine , New tranny , New fuel injectors and New radiator .All my accesorires , altenator , waterpump etc have been changed in the last two years to ! My whole ignition system is new ! It's like a brand new thirdgen !! Ha but I sure have paid for it !!!:lala:
Old Apr 30, 2002 | 07:12 AM
WaynesRS's Avatar
ttt
Old Apr 30, 2002 | 08:08 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
same one i got, just measure your old one wayne, width and height, yes no drain plug, no biggy take off the lower hose, i had to get a new 15lb cap from griffin......i ditched the stock shroud,i just cut it off of the fan then fabricated L brackets for the top and used tie wraps thru holes in the rad support on the bottom and just drilled holes in the plastic surrounding the fan, i tried screws but they just mad the plastic flex and then the fan rubbed........while your at it throw some metal hoses on it , they dissipate heat alot better than the rubber crap.........i got a 48" or 40" cant remember now from summit for $100........it comes with enuff reducers and hose ends to make both upper and lower hoses................the ends are rubber i think they look ok, you could get chrome covers for the ends but for another 60 bucks i figured it would be money wasted
Old Apr 30, 2002 | 09:41 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I'm a little confused as to how this radiator fits. It sounds like the radiator support cover doesnt fit correctly, so I guess my question is do you have to modify it to make it fit correctly, or do you have to ditch it and make your own brackets? Also, where is the tranny cooler mounted? Will the stock fan mount to the new radiator? I REALLY need a new radiator, my stock one is starting to leak a little, and my car overheats a bit in traffic when I have the AC on. I'm going to be dropping in a new eninge thats gonna need MUCHO cooling power, too, so I had better get on the ball so I dont end up stranded. It would be AWSOME if someone could make a tech article on installilng an aftermarket radiator and tranny cooler, hint hint....
Old Apr 30, 2002 | 09:42 AM
Scott_92RS's Avatar
Car: 1992 RS
Also, what are the part numbers of the items you bought?
Old Apr 30, 2002 | 02:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could call Summit Racing 800-230-3030 and get a part #. Griffin probably has a website somewhere, too.
Wayne, you would just buy radiator hoses to fit that different inlet/outlet appliation. 'Fact, you could do like Mark did, and use a universal hose covered with the braided sleeving. I put the braided sleeve over my factory hose; looked nice, but man, it's beat up by now. Summit sells lengths of radiator hose with the sleeving already on 'em... you'd just need to buy the dress-up hex-covered clamps.
And I bet your lower hose (driver side) curves downward, then up, right? That's the little sucker that prevents us from having a Wonderbar!! Stupid downwards loop. Our lower outlet is angled down, and on cars like MarkSheild and GreenPro's, the lower outlet goes straight back. That prevents any interference with a Wonderbar. (See http://www.sethirdgen.org 's tech area for info on a wonderbar install.)
Green, did you get a radiator with the trans cooler built in, or are you just going to run the B&M unit on it's own? (I have the B&M one, but not quite as big! I used it in-line with the stock cooler.)
Old Apr 30, 2002 | 02:42 PM
wasp's Avatar
get a seperate cooler with a fan...i mounted mine in front of the rad..........just had to remove the hood safety latch and install hood pins since the latch goes thru the ..........just pop the hood and look youll see what i mean........i really dont think there is a need for a tech article on replacing a radiator......its pretty straight forward if you use that thing on your shoulders and take some measurements ahead of time its a no brainer really
Old Apr 30, 2002 | 03:16 PM
Bad Boy?
My bill from Summit (minus stupid border fees) was $250. Keep in mind that I havent replaced my rad hoses; I am going to mock it up first to see what sort of lengthes/angles involved...
Old Apr 30, 2002 | 03:19 PM
Ya, sucks to be me. Pressure checker Swiggly Signature wasnt as careful as he should have been when he tested the thing. Oh well, I'll get to spend more time with it out of the car...
Old Apr 30, 2002 | 03:27 PM
Part numbers... I'll run and get the reciept. Just a min...
Here we go-
GRI-1-25272-X (31x19 'Nascar Style' Griffing Race Radiator)
BMM-70264 (B/M Super cooler less than 24000 lbs; biggest one)
And I bought a cheap catch can ot replace the stock resevoir...
Hope that helps! Going to mock it up, talk to you later...
Old Apr 30, 2002 | 03:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Those Summit catch cans, I was wondering, can they be made into a regular overflow tank like ours? What if our radiator overflow connects to the bottom petcock of the catch can, the top "input" of the catch can is left open, and we open the petcock?
I have a silly little plastic overflow tank, $10 from Whitney; I mounted my MSD where my regular overflow is supposed to be. But man, that plastic tank looks cheap... in fact, it cracked on me, and I have a small leak.
Old Apr 30, 2002 | 05:17 PM
WaynesRS's Avatar
Thanx so much guys for all the help ! ...I'll have to keep ya'll posted , but Im almost 99% I will be getting a Griffin !
I was thinking about getting a BE COOL rad before I saw the Griffin , but no thanx I think I will pass on the $549 price
Old Apr 30, 2002 | 05:20 PM
WaynesRS's Avatar
I forgot to tell you guys , on the way home from school today a papertowel got stuck on my airdam . about after a min of driving like that , it made my car run hot , but I didnt realize thats what it was making it run hot until I got home .But it was covering half my airdam .Anybody ever had this happen to them , heh .
Old Apr 30, 2002 | 05:59 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
ha jeff gordon had that happen sunday. poor jerk. i love it! i cant believe that guy want to ditch his wife and become a ******.:lala: she is f-ing hott!!!:hail:.lol
Old Apr 30, 2002 | 06:58 PM
Installation installation- (lol)
The rad has no trouble clearing the hood, but as everyone knows, the factor radiator fan upper support is useless. There are 1 places where the radiator core support interferes with the side tanks of the radiator; without those points the rad would sit perfectly straight
Good to hear Wayne! It is a good deal and an amazing radiator... not that that six makes that much heat, but that is a whole other conversation...
Old Apr 30, 2002 | 07:20 PM
DM91RS's Avatar
Car: 91 RS
Installed mine a week ago.
Old Apr 30, 2002 | 10:36 PM
WaynesRS's Avatar
heh , you would be surprised if you rode (spelling ? lol) in it man . It's mildy modded as you can see in my sig .I have read articles in Car Craft and even seen old 305s run 17.30 or 17.45 .Im NOT saying yours would run that . but these were old ragged out ones that needed tune=ups and some work done ..Not to long ago I had my car in the shop and the mechanic that worked on it raced Irocs in the 80s and he told me he was very impressed with my car . BUT I know its no V8 power ! I was like Really ? lol I want a V8 or IROC bad , but I want to keep my V6 to cus I love it !
Old May 1, 2002 | 12:11 PM
gruveb's Avatar
Car: 1989 IROC-1
The griffin radiators say they are for racing applications only.
Why is that?
Could I use one in my daily driver?
Old May 1, 2002 | 12:31 PM
Scott_92RS's Avatar
Car: 1992 RS
Why is that?
Sure, just go full throttle from every stoplight
Old May 1, 2002 | 12:40 PM
Car: 99 Formula
Axle/Gears: 342
Why is that?
I use it every day with no problems.
Old May 1, 2002 | 01:51 PM
gruveb's Avatar
Car: 1989 IROC-1
Mark,
Would you buy one again if you had to do it over again?
Were there substantial cooling benefits?
What size is it, the 31 x 19?
Old May 1, 2002 | 01:54 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, I would buy it again, I couldn't really tell you the difference cause at the time I was overheating with the stock radiator but it was due to another cause. Right now cruising my temp gauge is at the temp rating of my stat, and maybe goes 10* higher while in traffic.
Old May 1, 2002 | 09:50 PM
WaynesRS's Avatar
That's a good excuse incase ya get pulled over ! Well officer I have to drive like that , see ever sence I installed my Griffen radiator its recomended for race applications .Atleast I beat that mustang officer !:sillylol:
Old May 2, 2002 | 07:25 AM
Scott_92RS's Avatar
Car: 1992 RS
Hehe, that'd be cool, but I'm not so sure the cop would see the humor in it
Old May 2, 2002 | 04:16 PM
He, he, he...
With all the street racing going on these days, I dont know if he will be too amused...
It is nice to know that the rad would handle the extra fire power used if you want to hot lap it at the stip or track; definate plans for my car.
91 rally sport
22
Apr 5, 2016 05:06 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
