Help Me With Camshaft Specs
Old Apr 29, 2002 | 11:07 PM
Tyler-88's Avatar
All forged bottom end on a 383. prolly n/a with an lt1 intake and speed density electronics with accell dfi and afr 190 heads. roller cam for sure, what else do you guy need to know? i want power from 2000ish up to the mid to late 5k's. i really dont want a stall but i might have to go that route. i want a nice idle so i still have brakes at an intersection
thanks alot guys, i dont know camshafts at all
Old Apr 30, 2002 | 08:58 AM
Jester's Avatar
Since you'll be running DFI, a decent intake, and don't need the power band to come in till 2000 or so, you can afford to go fairly big cam wise. I forget the grind number, but Comp has a hydraulic roller grind that had a .050 duration of 230in/236ex in a 112LSA. I'd get that or one similar, maybe have it ground on a 114 LSA instead.
Don't underestimate the value of a converter tho, even a fairly low stall Vigilante or Yank can do wonders for a car.
Old Apr 30, 2002 | 09:30 AM
Vader's Avatar
Re: Help Me With Camshaft Specs
Originally posted by Tyler-88
All forged bottom end on a 383. prolly n/a with an lt1 intake and speed density electronics with accell dfi. roller cam for sure, what else do you guy need to know? i want power from 2000ish up to the mid to late 5k's. i really dont want a stall but i might have to go that route. i want a nice idle so i still have brakes at an intersection
Umm, not to pick nits, but you already have a "stall"... The converter that came in your 'F' car should have about a 1,600 RPM stall speed. Raising that to 2,200-2,400 RPM could be a good thing, especially with an LT1 intake.
In order to maintain a respectable idlequality and vacuum, you really need to look at a dual pattern cam like the Comp XE series. Comp 07-304-8 (.500/.510 210°/220°-114° LSA) will give you plenty of lift with 1.5:1 rockers and decent idle. Call them and talk about your needs and get their reccomendation.
Old May 1, 2002 | 03:40 PM
Tyler-88's Avatar
noone else has any recomendations?
Old May 1, 2002 | 04:35 PM
primer84z's Avatar
like vader says call comp cams. they know everything about cams and which one will work good for your needs.
gord327
Oct 3, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
GTAman
Sep 26, 2015 02:01 PM
wstephan96
Sep 25, 2015 04:28 PM
angel2794
Sep 8, 2015 06:22 PM
