blm's low ?
Old Apr 29, 2002 | 11:17 PM
jester111's Avatar
blm's low ?
Hey guys
I just had a scanner hooked up and the blms were at 100 and the os crosscounts around 10-20. other than the evap., and fuel press reg what would cause this? If the fuel press reg is not ruptured and leaking it should be ok right?
any suggestion?
thanks in advance!
Old Apr 29, 2002 | 11:47 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
A lot of things can cause a "rich" condition like that. Oxygen sensors, a faulty MAF, leaking injectors. Also, you mention the fuel pressure regulator. Just because its not ruptured doesn't mean its function properly. Make sure the regulator is getting vacuum, or else it will cause max fuel pressure all the time which will cause you to run rich.
antman89iroc
36
Jan 31, 2016 08:42 AM
BrianI
Oct 3, 2015 12:57 PM
Giocio
Oct 1, 2015 12:20 PM
Damon
Sep 26, 2015 04:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
