Which is faster?
Old Apr 30, 2002 | 12:54 PM
DakotaSLT's Avatar
Which is faster?
which car is faster, stock for stock, an LG4 powered Z-28, or an LO3 powered RS (assume same gears, trans, etc., just differences in coupe's weight and engine), also, which has more build-up potential?
Old Apr 30, 2002 | 12:57 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd say they're about equal, though the LO3 has a bit more power. I've heard of a near stock RS run 15.5 though most are probably high 15 low 16 just like an LG4.
I'd say the LG4 has more potential, didn't they have better heads to port?
Either way on both motors, the cam, exhaust and heads hold the motor back.
Old Apr 30, 2002 | 01:17 PM
mss's Avatar
mss
the lo3 uses swirl port heads i believe . in 87 the lg4 and the lo3 were exactly the same with the exception of 5 ft lbs of tq . but for the most part , they will run very cloe if not equal
Old Apr 30, 2002 | 01:21 PM
Adam62083's Avatar
L03 will win, plus get better mileage and all that.
But from a performance venture, they both totally suck. Until you change the cam, intake, and heads, you've got a pretty crappy 305. It was designed just to be a middle engine option, not something that performs.
Old Apr 30, 2002 | 03:02 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
lo3 baby!!!
actaully I'm dealing on a '88 350 tpi as we speak, so that all might change
Old Apr 30, 2002 | 03:43 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
kind of a toss up. my LG4 has run a 16.2 in the quarter bone stock with the original 90k mile plugs and wires, and its an auto! i think i can do better than that time however, (my roommate raced the car that time and it was only his 2nd time drag racing), cause it got a 2.4 60ft. surely i can get at least a 2.2 which would put it solidly into the high 15s. if i ever race a LO3 in my Z, ill let you know the results
no green
Mar 3, 2016 05:19 PM
toones
Jan 6, 2016 06:00 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
Americanmouse
Sep 7, 2015 12:10 PM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
