questions on S/R torquers
Old Apr 30, 2002 | 10:24 PM
91rsrider's Avatar
ok when i rebuild my 305 im going to get these heads.my question is am i better off going with 1.6 or 1.5 rockers with an LT1 or LT4(possibly HOT if i can find one).ive searched but couldnt find a clear answer.thanks for any help!
Old Apr 30, 2002 | 10:33 PM
Vader's Avatar
91,
As a general rule, I like to get the cam lobe to do all the lifting with standard ratio rockers (1.5:1), then have the option of increasing lift with higher ratios.
Make sure you know the cam specs before you order the heads, since you will want to get the correct springs for your cam the first time.
Incidentally, the LT4 "hot" cam provides rated lifts with 1.6:1 rockers, so make sure you compensate when comparing cams, since most other cams will be quoted with 1.5:1 rockers.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
