Holley Street Dominator
Old May 1, 2002 | 06:45 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Does anybody know if the Holley Street Dominator intake manifold with a 600cfm Holley Carb will fit under the hood of our cars? I have an 82 Z-28 with the LU5 CFI "composite fiber-glass" hood. They claim that it is 1.25" taller than stock. I was also thinking about the Weiand Stealth. Which on would be better for my LU5 305cid. I will also add an new cam such as the comp Dual energy DEH255. I might also add a 2000 stall converter later. Any other suggestions?
Leigh
Old May 1, 2002 | 09:39 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
im curious about that Weiand Stealth, too. i want to get one for my trans am to just about finish up my engine, but i dont know if it will fit under the hood
Old May 1, 2002 | 09:52 PM
SoCo80p's Avatar
i ran a holley street dominator on my 80, it is a quite tall manifold, the only high rise dual plane manifold that i know of, that is a maybe for fitting, but the stealth is way lower, i dont see why would have a problem with it
Old May 2, 2002 | 02:01 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
So which intake do you think is better for my setup?
Old May 2, 2002 | 02:21 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
It won't if you want to run an air cleaner. I had one on my 82 bird and with a 1 1/4 drop base air cleaner and a 3 in element It stuck through the hood almost an inch. It might fit with a 1.5 in air cleaner, but I don't think an engine would breath well through it.
Later
Spud
Check out my website the engine pic are of the street dominator.
Old May 2, 2002 | 02:34 PM
84TAProject's Avatar
I dont think it will clear a stock hood. I have a dominator manifold on my T/A, but a cowl induction hood. I can see the top of the aircleaner through the slot (I need a bigger element, soon it will again be through the hood) and its a 2.5" elemtn or so. I doubt it will clear the stock hood, and used it as an excuse to get the cowl induction without being "fake".
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
