Please Help Asap!!!! Stuck At Work!!!
Old May 1, 2002 | 08:36 PM
5.7lformula's Avatar
My car just flat out wont start. It has power to everything, even the fuel pump but when i go to actually start it nothin. dosent crank or anything. I already tried the VATS bypass thing and still nothing. It did this once before then after a little while it started back up. Im stranded at work right now and have NO idea what to do.
THanks, Jesse
Old May 1, 2002 | 08:43 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Same thing happened to me at school, I knew what the problem was, a cooked starter selenoid. Just got a jack and starter and away I went.
SlowStangEater's Avatar
Re: Please Help Asap!!!! Stuck At Work!!!
THanks, Jesse
Have you tried jumping it??? It could be the start of Heat Soak on the starter...... If thats the case, use a pair of pliers or something to touch the contacts of your starter..............if you can reach.....Otherwise you have to wait unless its a manual.
Old May 1, 2002 | 08:46 PM
A jumpstart should do it...........Otherwise waiting is the only answer. If you have a manual pop the clutch. If it turns out to be the starter solenoid..........Buy a new starter, heat shield, and a summit remote solenoid kit.......Its worth it!!!
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
is the starter getting juice? you may have fried a fusible link. or your starter just might be bad, try hitting it with a wrench or something, this may be a TEMPORARY fix
Old May 1, 2002 | 08:50 PM
Yes Very Temporary Once you have this problem your starter is more and more prone to it happening..........For Example my car wont start for 5 hours after 10 minutes of driving It will be fixed tomorrow.........I hope:hail:
Old May 1, 2002 | 09:00 PM
I tried hittin it with a hammer and nothin. I cant hear it turnin either. Its dark where im at so i cant really see waht im doin as far as the touchin the 2 screws. There only 2 on the starter??? If so i might be able to get to it. I drove it to work this morning then around 14hrs later it wont start. What is heat soak?
Jesse
Old May 1, 2002 | 09:05 PM
Re: :-(
Jesse
Well its not heat soak if its been 14hrs.......Heat soak is when the solenoid gets to hot to operate and after the car is shutoff it wont work -without a jump for about an hour or so. Sounds to me like youve got a truly bad starter..........But there wasnt any warning so thats strang. To bad you dont have a manual. Umm try the VATS bypass one more time. If that and a jump dont work.........I can only honestly wish you the best of luck.....Good Luck.
Old May 1, 2002 | 09:06 PM
One more thing...........See if the battery cable has a good connection to the solenoid..........It will be tough to see but You never know. Remember KISS -Keep it simple stupid
Old May 1, 2002 | 09:41 PM
breathment's Avatar
make sure you have a good connection with the ground on ur battery. I have a friend who would have a simular problem as yours, but a couple times a week, he had power to everything, except the starter, turned out the ground on the battery wasn't connected that good..
Old May 1, 2002 | 10:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Like said, make sure the ground connection is good and tight. I had this problem numerous times leaving me stranded until it was figured out. It won't even take a jump when that isn't secure.
Old May 2, 2002 | 10:34 AM
STILL STUCK!!!!
I went out ther again and it fired right up, I turned it off and tried it again and NOTHING!!! Possible relay??? I have it it and what not. I Just dont want to swap starters just to find out that it still does nothing. Is there anyway to check the relays???
Jesse
Old May 2, 2002 | 12:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Isn't that what VATS does if the key isn't read properly? How'd you bypass it?
Old May 2, 2002 | 01:04 PM
TBurke's Avatar
Beat starter. If it starts again, drive it home.
Old May 2, 2002 | 02:21 PM
Car: 99 Formula
Axle/Gears: 342
Check the ground thoroughly, I've had it where one second power to nothing, then I guess the ground moved just enough and the car would start.
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
dutch930
Sep 11, 2015 06:58 AM
backtothe80s
Sep 5, 2015 12:39 AM
