how can I run cooler?
Old May 2, 2002 | 11:24 PM
5.7L OF JUSTICE's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7L TPI
I have a question. On normal days my car always runs between 190 and 200 degrees which is fine with me. But on those 85+ degree days it starts running hotter. How can I relieve this. The car has a history of overheating, before I got the car it had cracked heads which I have since then replaced. Everything works fine now. I dont leak coolant, I have two fans running at all times, and my radiator is in good condition. How can I keep it running nice and cool even on hot days?
Old May 2, 2002 | 11:27 PM
breathment's Avatar
get a 185* or 160* thermostat. and use like a ratio of 10% antifreeze to 90% water. or if u aren't running A\C then 100% water with some water wetter..
Old May 2, 2002 | 11:30 PM
Engine: 5.7L TPI
I do have a 185 degree thermostat and run about 60% water 40% coolant.
Old May 3, 2002 | 12:20 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Try some Water Wetter or get a 3 core aluminum radiator. Do you have a tranny cooler, that will help too.
toronto formula
Nov 10, 2015 06:17 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
TreDeClaw
Aug 14, 2015 06:58 PM
