What Now????????????
Old May 3, 2002 | 12:09 AM
5.7lformula's Avatar
As some of you read i was havin a startin problem. Well the problem was the starter. I got that swaped out and everything was good. On the way home all the sudden i lost power to EVERYTHING!!!!!!!!!! I have nothing!!! and icant fit under my car, (and no im not fat :-) i just cant get to where i can see thingsfrom the bottom. Does anybody know what it could be? i was told it could be a link or most likley a loose wire off of the starter. If its not one of these anybody have any other suggestions?? Right now my car is sittin onj the side of the road. I dont like the thought of that to much,
Jesse
Old May 4, 2002 | 07:30 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
for sure check all your connections, Battery and starter.....sounds like something came loose.....check your fuses also, and the ground strap to the engine...
Old May 4, 2002 | 05:33 PM
Vader's Avatar
...and fusible links at the starter.
Old May 4, 2002 | 07:50 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I'd bet the hot lead and accessory wire off the solenoid terminal came loose. Jack it up and tighten her up.
