OK is this a myth or what? Distributor Q
Old May 3, 2002 | 04:55 PM
iroc22's Avatar
Is it just a myth that you need a bronze distributor gear for roller cams? My stocker gear looks plain, but there's so much oil on it I can't really tell.
Erson says that all roller cams require one, Mr. Gasket says that plain steel gears are ok for hydraulic roller cams.
The guy at the local speedshop that rebuilt my distributor says I dont need the bronze gear either so...
Old May 3, 2002 | 09:43 PM
boogie's Avatar
If you are talking hydraulic roller a bronze gear is not necessary. Billet steel solid roller cams require a bronze dist gear unless it has an iron gear pressed on it. GM # 10457708 is the correct iron gear for late model distributors such as yours.
Lonnie
Old May 3, 2002 | 10:29 PM
iroc22's Avatar
Alright thanks, that clears it up.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
