I really need help here...PLEASE!!!!!!
Old May 4, 2002 | 10:14 PM
TBI305Camaro's Avatar
ok my car died on me yesterday...lately sometimes it feels like it isnt piulling past 3k rpms and feels like the spark is getting weak...im getting no spark to the plugs now at all...it wasnt the ignition module..coil is new but who knows...what should i do? i got the distributer pickup thing but im gonna have to pull the distributer to put it in and everything...what should i do?? should i buy a voltmeter so i can test the pickup for shorts like the haynes manual says? how would i know if the distributer is bad?!? please help i dont wanna drive the lumina anymore
Old May 4, 2002 | 10:27 PM
WaynesRS's Avatar
Sounds like the pick-up coil to me . Im in the same situation as you are right now man . I have new plugs , new wires , new cap and rotor , new coil . Today it died twice on me . I came home took the cap off to take a look at my pick-up coil . My pick-up coil is about to take a crap on me . Tommorrow I will be changing it .If this doesn't work . I will be checking the fuel pressure and changing the fuel filter next . But I really think its my pick-up coil .
If your not getting spark , it sounds like your pick-up coil !
Hope this helps !
Goodluck
Old May 4, 2002 | 10:44 PM
ive got it sitting here i guess ill stick it in tomorrow...i have a feeling my car is gonna run better if thats it because lately its ran funny...wont hardly pull past 3k when to the floor...falls on its face then soon as it shifts pulls hard again. how hard of a job is it? think im gonna screw my timing up when i take the distributer out?
Old May 4, 2002 | 11:03 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Pull off the Coil-to-Cap wire, and crank the enigne. If no spark comes from the coil terminal, then start there and work your way back.
Old May 4, 2002 | 11:38 PM
no spark coming from either....the cap coil part or the coil itself....even tried grounding it....nothing
Old May 4, 2002 | 11:50 PM
WaynesRS's Avatar
no spark from the pick-up coil or ignition coil ?
Are you testing with a multi meter ?
Old May 5, 2002 | 10:09 AM
no im not testing with a multimeter i need one tho
