Edlebrock Centerbolt Aluminum Heads
Old May 6, 2002 | 04:57 PM
NickyCamaro's Avatar
I am confused about pushrod length. I read on the Jegs website that with stock rockers you must have a pushrod .1" longer than stock. So does this mean that any roller rocker or non-stock style rocker can be used w/ a stock length pushrod? Thanks
Old May 6, 2002 | 10:13 PM
Guest
Guest
Posts: n/a
I wouldnt bet on it. It might be that you need the longer ones, or shorter ones. Depends on the parts.
If you want my .02, the last thing you get is the pushrods. I know its a slow and lousy method, but safe. Throw the stock ones in there, turn the engine and check the pattern. Usually I can guess pretty close from there what pushrod I need. Other way is to get one of those adjustable pushrods that are for checking pushrod length and then figure out what size you need.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
