milodon gear drives
Old May 7, 2002 | 01:38 PM
dejaybrian's Avatar
milodon gear drives
i am lookin at purchasing a milodon gear drive The 3 gear style Will this still interfere with the knock sensor on my engine.The way im thinkin it might not cuz its fixed and doesnt float like the 4 gear types..thus it wont hit the block when the engine is running causing the knock sensor to retard the timing. anyone have this in there car??? its a bit expensive and i was told that all vibration will shorten the life of the cam??? is this also correct??
Old May 7, 2002 | 01:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/techbb2/sho...hreadid=105408
Old May 7, 2002 | 01:53 PM
dejaybrian's Avatar
allright let me rephrase that and screw the gear drive ... How much for a good set...and are there packages where you can get the whole thing all in one box...cam lifters, chain, etc
Old May 7, 2002 | 02:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IIRC the good set from Comp is about $60. Or, they package cam only, or kits with cam plus lifters, or with that plus a timing set, or with pushrods and springs and retainers and keepers plus all the above, or even with their steel roller-tip rockers added to all that. Seems like it's about $100 less to buy it like that than to buy all those parts separately. I don't know details for sure, but several of the other major cam companies (Crane, Lunati, etc.) offer similar packages.
Old May 7, 2002 | 02:25 PM
dejaybrian's Avatar
allright and thanks once again...lol ive been out spending a bit to much money today...bought a transgo reprog kit, and a corvette servo kit, and i also got that airfoil (30 bucks)...so im off to check out some cams now...
do you suggest any specific grinds or part numbers to look at???
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
