Got A Weird One
Old May 7, 2002 | 05:45 PM
tpi_roc's Avatar
Got A Weird One
Ok guys, this one's got me....
World Products Sportsman II's, I just built up the block when it came grinding to a hault when I couldn't get my CTS in there for my tpi. So reading WP's site I run out and get a 1/2 - 3/8NPT adapter...
Bring it back, well the CTS fits in it perfect, but it slides right into the passage for it, without even threading (to small). So I bring it back and I hand thread it as far as it can go (CTS) and it takes about 1-2 threads, Then i get a wrench and start goin at it thinking being brass the sensor will give before the heads, Well it threads in about 2-3 threads (give or take) and it starts offering enough resistance to worry a little, So i back it out and the first thread is STARTING to lay over itself (cross threading?) Now there's no way the WP's are metric, but they dont seem to be NPT, so is something way off, Am I crazy, Or is this by design? Maybe the tight tappered fit is for a super tight seal???
Please give any info as I'd like to get passed this one last annoying hitch and drive the dam.n thing!
Old May 7, 2002 | 06:11 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
could it be a pipe thread? i'm clueless otherwise
Old May 7, 2002 | 06:14 PM
tpi_roc's Avatar
Thats the thing...
NPT is a pipe thread, no?
National Pipe thread?
thats what WP lists the sensor hole to be, but the sensor only goes in 2-3 threads then starts to fold the 1st thread over, maybe its tapered and supposed to? I dunno, but its certainly weird and DEFFINATLY hindering progress.
Old May 7, 2002 | 09:30 PM
Tom84L69's Avatar
Car: 84 Z28
oh, i didn't know what NPT meant, some of your acronyms sound like military talk!
pipe threads are supposed to tighten up like that, that's what makes them seal. They do go in more than 2 or 3 threads though, I'm sure you've experienced a pipe thread. Don't try and reef the thing in if it is ruining threads. could you tighten it as far as it will willfully go and try it to see if it leaks?
Old May 7, 2002 | 09:48 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
What's a cts? You talkin about the coolant temp sensor? If you used a npt pipe bushing (adaptor) it should work right unless you cross thread it. It will definitely go in more than 2 or 3 threads.
Old May 7, 2002 | 10:39 PM
tpi_roc's Avatar
I didn't use an adapter, I tried to because of how it threaded funny, but as is (installed) there's no adapter, just straight in
I dont know if its more than 3 threads or not though.
db057
Jan 10, 2020 08:55 PM
F-body-fan
Mar 1, 2016 07:21 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
BWilcox
Sep 20, 2015 12:19 PM
