ARS backwards firing order? 69 truck 350.
Car: 1989 C4
Axle/Gears: 307
I need to know the funkey wire placement for an ars backwards points distributor, I know the FO is still 18436572 but do you run them backwards? Can I just do a 180* with the distributor and go to standard wire placement.
I dont like the older systems at all!
I dont like the older systems at all! Moderator
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
18436572 Rotation is clockwise. #1 plug wire can be anywhere on the distributor that works best.
TheTraut88
Sep 7, 2015 05:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
