Bouncy Idle???
Old May 12, 2002 | 12:08 PM
MurphsIroc's Avatar
Bouncy Idle???
Hey guys, I have an 88 IrocZ Camaro with the 305TBI. I have 110k on the engine and have been experencing a rough idle. Want can cause this? Misfiring injector? plugs? Once in a blue moon it will just stall as well. What can be the problem?
help would be greatly appreciated. Thank You
Old May 12, 2002 | 01:38 PM
Vader's Avatar
Murph,
I'd clean the TBI and IAC ports. Check the fuel pressure and pump flow, and take a good look at the ignition system. With the phenomenon being intermittent, I would tend to rule out plugs, cap, rotor, and wires. Either the HEI module or coil could be an issue, but inspect/test everything anyway to be sure.
Any trouble codes?
Old May 12, 2002 | 10:41 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
I had a problem with this similar thing in my 89 IROC about a year ago. The idle would be fine until the car warmed up and then it would bounce from about 300 to 800. Turned out that the O2 Sensor had gone out and it wasn't reading so it F'd up the idle. Just a thought...hope you figure it out...I know how much of a pain it can be.
Ryan
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
