Crane 1.6 "blazer" roller rockers
Old May 12, 2002 | 09:35 PM
tpi_roc's Avatar
Has anybody here installed crane 1.6 roller rockers and noticed a shift in valve train geometry for the worse?
I recently built up an engine and added the 1.6's and immediately noticed how close they were to the exhaust side of the valve stem. After trying to find my problem it appears it was the rockers themselves. IT appears that the crane blazer roller rocker have a longer valve side of the rocker instead of a shorter pushrod side?
I put the same rollers on a 305 i had sitting around to see what happened, again the roller tip was way out on the edge of the valve.
So who else runs cranes? Both successfull and unsuccessfull installs notes appreciated.
Old May 13, 2002 | 10:33 AM
tpi_roc's Avatar
Any machinists build an engine with them?
Old May 13, 2002 | 05:50 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Good thing you brought this up I was going to order a set of 1.6's now I dont know.Do you have a adjustable pushrod to see how much they are off?
Old May 13, 2002 | 05:57 PM
tpi_roc's Avatar
Yes I do.
they might be energizer rockers.
I'd always suggest comp way before crane, but these were cheap, now I know why.
cranes machining tollerances are +/- .010
I've either got ford roller rockers (+.050 over sbc) or they decided to extend my valve side instead of decreasing the pushrod side of these rockers.
I'm going to take some measurements from the center of the fulcrum to teh center of the roller tip to see where mine land within cranes specs.
Either way, I'd recommend comp/harland/anybody but crane
Old May 13, 2002 | 06:22 PM
e-man's Avatar
Car: 89 formula
Engine: 383
t The blazers are on the top energizers bottom.Which ones do you have?
Old May 13, 2002 | 07:40 PM
Dr. Pepper's Avatar
You need a different length pushrod. I would consider that far from unusual, especially for changing the rocker ratio.
Old May 13, 2002 | 07:42 PM
tpi_roc's Avatar
trust me.
I dont
but thanks anyways
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
