Cam for coputerize carberation 87 camaro
Old May 12, 2002 | 09:59 PM
87camarosc's Avatar
I have an 87 camaro with 305 computerize carb I want to put the heads, intake, and carb on a 76 350 out of a van. I would like to know how big of a came to use in it.
Old May 31, 2002 | 08:51 PM
Jza's Avatar
Jza
Thought I'd give you a little bump to the top, as well as put you in a better place for good answers.
Old Jun 1, 2002 | 08:27 AM
Vader's Avatar
The heads from a '76 350 are going to be a bad choice. The earlier "smogger" heads had very small valves and poor flow volumes, and intakes to match. Beyond that, the chamber volume of the 350 heads (probably 76cc) is going to drop your compression ratio to extremely low-performance levels, like 7.5:1 or less. Lawn mower engines go that low, but not much else.
Depending on the heads you have on your 305, you may already have better flows, and likely already have much better compression. And there are a lot better choices for replacements.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
