Installing the Distributor.
Old May 13, 2002 | 12:39 PM
yyz28's Avatar
Need some input on this. I've got the car back together for the most part (for those of you who remember I've been re-building this motor that, when I bought it, was shot...) and I'm ready to put the intake back in, re-install the distributor, and fire her up.
Here's my question. I installed the cam with the timing marks at 6 and 12 o'clock, like the manual tells me, and after having adjusted the rocker arms, I have BOTH timing marks at TDC. I have re-installed the pulley and timing marker, and I'm not sure where I should have the motor turned to when I re-install the distributor OR which cyl. to point the rotor to...
...any input would be appriciated! Thanks!
Old May 13, 2002 | 01:05 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
once you determine that you're at TDC, the rotor should be pointing toward the #1 cylinder contact on the cap. That'll get you real close.
Old May 13, 2002 | 01:13 PM
yyz28's Avatar
...how can I determine TDC with the heads on and the timing cover in place?
Old May 13, 2002 | 01:16 PM
Jim85IROC's Avatar
I usually just look at my timing tab in relation to the balancer, then put your finger in the #1 spark plug hole. blip the starter a little at a time. As your timing tab approaches 0*, see if you finger is getting sucked in or pushed out. at TDC your finger will push out, and at BDC, your finger will have suction.
Old May 13, 2002 | 05:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could also put a long phillip's head screwdriver into the spark plug hole, and see at what point the screwdriver stops rising. Oh sure, you might put a little scratch in the top of the piston; if you're that worried, use a long piece of old, stiff vacuum hose.
Old May 14, 2002 | 08:58 AM
Vader's Avatar
Or you could remove whichever rocker cover is easier and watch the rocker arms.
If you remove the left rocker cover, the #1 cylinder will be on the compression stroke at TDC when both rockers are in the closed position.
If you remove the right rocker cover, the #1 cylinder will be on the compression stroke at TDC when the #6 cylinder has one rocker (valve) in an open position.
When the timing marks on the balancer are at TDC with the #1 cylinder on the compression stroke, install the distributor with the rotor physically pointing toward the #1 cylinder location, as indicated in the diagram:
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
gixxer92
Sep 1, 2015 04:32 PM
355sbcTPI
Aug 19, 2015 04:38 PM
stalkier
Aug 7, 2015 04:49 AM
