intake backfire when cold
Old May 13, 2002 | 06:22 PM
MiSFiT's Avatar
i have a 305, edelbrock 600 performer on it and a weiand intake,the rest is pretty much stock,it backfires and stalls when its cold,really anoying i cant figure out why
Old May 13, 2002 | 06:40 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
the choke is not set properly. is it a new carb? if so then it definitely should be set i just bought my dad a new carb for his 68 torino and it does the same thing and all we had to do was set the choke. make sure it is set. dont know if that same thing applies to an electrical choke but i am sure someone else will help ya out as well.
Old May 13, 2002 | 06:52 PM
JunkHead84's Avatar
it could be a bent valve but thats not too likely. mine does the same thing if i dont let it warm up fir like 10 min, a rich fuel mixture can also cause it so like he said check the choke.
Old May 14, 2002 | 10:03 AM
Vader's Avatar
Actually, I was thinking advacned timing and a lean backfire, not rich.
Old May 14, 2002 | 10:20 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have the same problem too, if it's cold and I give it too much gas in D it will stall out on me. So I just let it warm up enough or if I can't wait for the car to warm up to like above 150*, I just take it easy on the gas.
Cornholio7979
Sep 20, 2018 02:31 AM
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
