How good is the KC4 oil cooler?
Old May 13, 2002 | 11:56 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
My '88 GTA has one and i was just wondering.
Old May 14, 2002 | 12:31 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I suspect it is not all that effective and somewhat reliant on how effective the cooling system is, judging from its design. But every little bit helps, so.......
I would be interested in some hard research info on it as well.
Old May 14, 2002 | 01:18 AM
poncho9789's Avatar
I have ditched mine and am going to use the B&M 28000gvw race tranny cooler to cool my oil.
I saw a study done were you got more engine life by lowering the oil temp. It was a dramatic result they came up with.
Old May 14, 2002 | 04:55 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I heard when the corvette switched to synthetic Mobil One, GM stopped installing the engine oil cooler. I understand the oil cooler is dual purpose, bring the engine oil up to operating temp faster (oil needs to be warm to flow properly) and then keep it at that temp.
Mine won't fit around the large harmonic balancer on the ZZ4
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
ezobens
Aug 19, 2015 10:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
TreDeClaw
Aug 14, 2015 06:58 PM
