Squealing Steering
Old May 17, 2002 | 07:38 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Squealing Steering
My car has started squealing when turning the steering wheel. When I first noticed it, I saw it was low on PS fluid so I added some more. But, it kept squealing afterwards. Any ideas what the problem could be & how I might go about fixing it? Thanks!
Old May 17, 2002 | 10:34 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm not sure, maybe a dying power steering pump. Never heard of that one though.
Old May 17, 2002 | 11:26 AM
1986sc's Avatar
Car: 92 Z28 92 RS Vert
Engine: 350 TPI 305 TBI
Transmission: 700R4 Auto (2x)
steering box
i had the same problem !! i kept putting bottle after bottle of ps fluid but it kept squeeling! so i took a trip to the junkyard and yanked a steering box. i replaced the box and it never squeeled again good luck!
Old May 17, 2002 | 12:29 PM
1986redbird's Avatar
sounds like the belts need to be tightened, when you turn the wheel you put alot of load on the P.S. pump and if the belts are worn or loose they will raise holly he!!
Old May 17, 2002 | 01:28 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I put new belts on it last fall, so i'll check those first....thanks guys.
Old May 17, 2002 | 05:12 PM
bob8748's Avatar
how long did you drive it when squealing. It was low, then you filled it, still squeals... pump is burnt.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
