Could A radiator cap cause this?
Old May 17, 2002 | 02:58 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
My car has been getting warm lately.....
I checked the coolant level today and it was very low.... I refilled it with water.
After driving the car around for a while, I opened the hood, and no coolant was in the overflow bottle, yet the car was at the normal operating temperature, so something should have been in there.
On the Stant radiator caps, there is a lever that releases pressure, when I pulled the lever up, it released pressure and coolant began to flow into the overflow bottle.
I can't find any other points of leaking in the coolant system. Nothing obvious anyways.
So my question is this:
Could the radiator cap be blocking the hose going to the overflow bottle and cause the system to be building up pressure, and allowing the coolant to escape through the cap somehow? And could that be causing my coolant level to decrease??
Has anyone experienced anything like this?
Thanks,
Daniel
I need to have all my problems solved before next thursday!
Old May 17, 2002 | 03:03 PM
Biochem's Avatar
Car: 2002 SOM z28
Go to Autozone (or equivalent), walk over to isle 4, and buy a 17lb radiator cap for $5.99 or so. If it isn't the specific problem asked here, you're only out $6 and you may have at least delayed or solved another problem...
Old May 17, 2002 | 05:15 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yep, I had a similar problem caused by a bad radiator cap.
Swap it out and see.
-Rich-
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
