verifying
Old May 17, 2002 | 09:39 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
verifying
how do you verify exacly where Top dead center is if you think the timing ring slipped on the damper???
Old May 17, 2002 | 10:20 AM
tpi_roc's Avatar
To know EXACTLY you should use a dial indicator.
To know roughly (within a few degrees) you need your #1 spark plug out, and you need to rotate the engine untill you're on the compression stroke for the #1 piston, then line up the timing mark at 0° on the compression stroke.
Old May 17, 2002 | 02:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take out the #1 plug, and stick a small diameter, somewhat compressible object such as a pencil or the like into the hole; rotate the engine while holding the pencil against the top of the piston as it nears TDC until the pencil reaches maximum delflection; observe the timing mark.
A dial indicator like roc says is of course the most accurate; but the other way should tell whether it's at least grossly off.
Pinguiclia
Oct 12, 2015 04:47 PM
AmorgetRS
Sep 28, 2015 09:33 PM
camarohelp
Sep 22, 2015 03:19 PM
david068513
Sep 18, 2015 08:37 PM
manifoldsrme
Sep 17, 2015 11:40 PM
